Results 1 to 10 of 14
- Apr 2007
- 82
August 19th, 2007 05:52 PM #1any recommended grease or lubricant. when i use wd40, parang sandali lang e. ok b yong ordinary grease (mga 100 petot) o dapat titanium o tgrease ( mga 300+ sa handyman).
or there is another post in another thread na lithium grease spray??
one more thing, di ba nakakasira ng paintjob ng hinge yong grease?
thnx
August 21st, 2007 10:30 AM #2
imho. you don't want to put grease in there. madumi masyado tsaka pwedeng mag sebo.
just continue in using WD-40 and spray if necessary or needed.
- Feb 2005
- 342
August 22nd, 2007 05:10 PM #3I read in other forums the thing to use is silicon grease/lubricant. The type you kinda see in some toys. I think there is a spray type (ala insecticide in a can) with a nozzle to get into the rubbering.
Dont put a lot and I think they say you need to start near the bottom and towards the top. If you can, open the panel to better lube the railing that holds the windows. This can also be used (or rather should be used) to lubricate the door hinges as well, to prevent rust and that annoying squeaking sound old doors get.
August 22nd, 2007 05:21 PM #5
guys, ok ba ang wd-40 for door hinges? hindi ba madumi? yung grease kasi ang dumi (yun ang ginagamit ng toyota casa before).
August 22nd, 2007 05:43 PM #6
As per honda manual White Lithium grease. Im using Optimol white T paste by castrol
- Apr 2007
- 82
- Apr 2007
- 82
August 22nd, 2007 07:57 PM #8
- Apr 2007
- 82
August 22nd, 2007 08:15 PM #10
Although I haven't tried it, marami nagre-recommend ng silicon lubricant, WD-40 brand has a silicon lubricant IIRC, I think I've read it from their website, I'm just not sure kung available sa mga Handyman, TrueValue or Ace.
I remember I saw a silicon lubricant dun sa malaking automotive store sa Megamall, (can't recall the name), hindi nga lang WD-40 ang brand.
I'm just finishing off my WD-40 then I'll try a silicon lubricant.Last edited by artpogi; August 22nd, 2007 at 08:18 PM.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
