Originally Posted by
mazerom
hi guys,
im just a newbie in the mechanics of car.i went to petron shop offering free inspection on the underchassis.i had been grieving on my frontal suspension part or transmission or absorber.it happened after i accidentally rolled through a set of deep holes.at smooth road, my car seems to move perfectly and smoothly but in some bumps when i dont do it super smooth, i feel and hear some "squeaking" noise in front.i feel that it has something to do with my shock absorber...im not sure though..
the diagnosis of the petron boys are oil leaks coming from the crankshaft/camshaft, tie rod loose at both ends, rack end problem..
now these are their estimations:
* labor for suspension?
replace tie rod : 320
replace rack end:320
wheel alignment:450
*materials for suspension?(not original daw)
tie rod : 3250 (ARE THEY CRAZY?? SUPER MAHAL NITO FOR REPLACEMENT PARTS)
rack end:3770 (DITTO)
*labor for oil leak
pull down transmission:1800 (LABOR IN THE SHOP IS 1500)
*materials
crankshaft oil seal:1014 (BIG OR SMALL?)
camshaft oil seal:975 (MAHAL!)
he also added these :
timing belt(orig):4940 (BILI KA SA HONDA IT'S PROBABLY 1500-1700 LANG)
tensioner:2145 (GET A REPLACEMENT TENSIONER, NOT MORE THAN 1K)
1. i'm just a newbie here.please comments
if the estimations are reasonable or if you have a
recommended shop near quezon city or fairview
or nearby cities...
2. i'm not sure if my timing belt was changed by the previous owner.
how will i know when to change it?
3. how much does a preventive maintenance costs?
my auto specs: 95hondacivicesi/91,000km/MT
