Results 1 to 12 of 12
    Dec 2002
    I have this turbo timer installed on a converted suv,
    the problem is I can't pull out the key while the engine is running, I have to wait for the timer to turn off the engine so I can pull out the key, w/c makes the timer useless kasi hihintayin ko ding mamatay yung engine. :confused: duh...
    what's wrong, is it the electrical of the timer? or is it mechanical?
    it has no manuals
    the turbo timer might be wired wrong.
    Anong SUV ba iyan?
    wiring nga yan. how to re-wire, that I cant help you. but make sure that the accessory wire is not attached to the TT, just attach the ignition wire to the TT. If that doesnt help, sorry.
    I used to have a turbo timer in my car... works fine except I can't arm my car's alarm as long as the engine's running. So the best I can do is to lock my car using the keys lang.
    Also my turbo timer hasa feature where if the timer is running and then if you step on the gas pedal, it will immedially turn off the engine.
    Dec 2002
    ghosthunter/karding,
    that's what I figured, electrical wiring, now I have to look for someone who can do it for me.
    any suggestions where I can have it checked, preferably in banawe area
    otep,
    secret.... :D although it's a transition vehicle
    maybe Team R Specs can help? Located along N.Roxas near Banawe
    my current alarm has these features as well. Step on any pedal, pop the hood, the car will shut off if no key is detected on the ignition and in "ON" position. I can also arm my security system while the engine is running.
    Dec 2002
    I guess the guys hat did my car, has no idea what they were doing, but at least it's working.
    ghosthunter,
    I know team R, I'll drop by
    any other place where I can have it checked
    magkano po isang turbo timer? for diesel po mahal po ba yan? very useful po? tnx
  11. #11
    Ano brand ng turbo timer mo? I wired my RAZO sport on my BigHorn and simple lang naman yung logic nya. If I remember it correctly 3 wires lang ginamit ko. Pag naka timer(engine running) of course you cannot arm the alarm and you also to have dis- able the feature nung alarm na nag-o-open nung doors after engine shut down. Also I installed a bypass switch na pag hindi ko ginagamit totally disconnected yung TT from my electrical syst. Nago-off naman siya automatically once you engage into D yung tranny but for safeguard purposes nilagyan ko ng switch. I can email you a basic wiring for an HKS TT but I have to look for it pa. Kinapa ko lang yung akin by using a multimeter.
    Sep 2006
    guys - just want to ask what are the pros in installing a turbo timer. what are its basic functions?
    thanks
question on turbo timer
