Results 1 to 8 of 8
    Sep 2008
    hi,
    mag tatanong lang po... kasi pumapalya ang makina na kotse namen, nung i-diagnose na (somewhere in banaue, inajust ang ung distributor para mahanap ang tamang timing. then they told me to kailangan palitan ung coil sa loob (ignition coil ba?)... unfortunately, walang available na coil during that time at wala rin distributor na available (too bad )...
    Car Model: Mazda 323 Familia 1999
    please provide any recommendations...
    thanks for your help
    Marami kasing dahilan ng pagpalya ng makina bro. When was the last time you had it tuned. Pwedeng yung ignition coil. Or pwede rin namang yung mga spark plugs, hi-tension wires, etc...
    Ibalik mo na lang uli sa repair shop. Have them change the parts one at a time para mahuli yung sira at hindi masayang ang pera mo.
    Goodluck!
    Last edited by jjmd3_787; September 8th, 2009 at 12:01 PM. Reason: tao lang po ...
    Sep 2008
    thanks for the tip. last tuned up was last April, kaka change oil lang din... so hindi pa muna pinalitan ung spark plug kasi ilang months p lang...
    kaka change lang din ng alternator kasi sira na... pero prior to this, pumapalya na talaga ung makina, pero naisip kaka tune up lang ung April. so nung an check sa banaue, ung ditributor daw ung problema...
    thanks...
    Feb 2009
    Quote Originally Posted by eric111498 View Post
    thanks...
    eric,
    three major groups of causes for misfires:
    1. mechanical condition-
    a. poor compression
    b. intake manifold leak
    c. carbon build up in the combustion chambers
    2. fuel problems:
    a. bad fuel
    b. poor fuel vaporization
    c. too rich or too lean air/fuel mixtures
    3. ignition problems:
    a. marginal secondary (high voltage) side of the
    ignition ( bad distributor cap, bad rotor, bad
    spark plug wires, bad spark plugs; any one or
    more of these will cause engine shivers
    b. voltage at terminal 15 (positive side of the
    ignition coil) is too low
    c. marginal distributor trigger (your car uses
    magnetic picku coil.
    to rule out the secondary(high voltage side of the ignition), turn your radio on AM (amplitude modulation) band and run the engine. if the secondary side has high voltage leak, you can hear it from the speakers as rfi (radio frequency interference). go through different frequencies on your AM band. the intensity and frequency of the noise will be proportional to the engine speed.
    jick
    Nov 2007
    eric,
    pareho tayo ng problema.... sakin mazda 1998 familia glxi....kapag malamig pa makina ok ang takbo pero after mga 15 mins pag nag nasa almost half na yung temp e ayan na...pupugak pugak na....ignition coil din ang diagnosis ng tumingin pero hahanap pa ko 2nd opinion... ang problema wala daw nabibili na coil lang kailangan yung buong distributor daw ang dapat palitan....patulong naman mga experts kung totoo yun....mahal kasi distributor mga lampas 6k daw....wala na ba akong ibang options? thanks....suplus kaya?
    Feb 2009
    Quote Originally Posted by turkey View Post
    eric,
    turkey,
    they have these parts on ebay. just the ignition pickup coil or just the ignition coil itself. they are compatible with mercury tracer and ford escort of the same year.
    jick
