Results 1 to 10 of 11
Tsikot Member Rank 3
- Aug 2004
- 2,452
July 23rd, 2006 11:41 AM #1hi Guys, i've got a Toyota Hilux Surf with 2.5li Turbo-Charged diesel engine. but it doesn't have an inter-cooler. i figure i slap on an after-market intercooler or Surplus inter-cooler fm. Starex would be nice to have better pulling power.
Question: - where can i find a surplus inter-cooler ?
- what size would be good?
- how much money should i be prepared to spend?
- good shop for installation (grntd no leaks)?
- what about the hood scoop, are there surplus available?
- Aug 2004
- 2,452
July 24th, 2006 11:21 PM #2what no one's familiar with inter-coolers? this Forum sux...
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 29th, 2006 12:05 AM #3sizing will depend on what you want from the turbo. if you are retaining stock boost then any moderately sized intercooler will do. you're going to have to manufacture piping tho to plumb into the system. a smallish IC should run you around 5-9k and then the plumbing will probably go for about 5-12k depending on the material (black iron or stainless and the diameter)
expect more lag sa system tho if you install an ic when there was none before.
- Aug 2004
- 2,452
July 29th, 2006 10:21 AM #4Originally Posted by speedyfix
actually i don't like more LAG... how to not add LAG and still enjoy the benefit of higher Top End power with the inter-cooler?
- Nov 2003
- 3,848
July 30th, 2006 11:15 AM #5problem with top mount is that you need to facilitate flow of air through it. that mean cutting the hood or putting a scoop. even then it will not flow as well as a front mount IC.
power should remain the same if you don't turn up the boost. the ic is just there naman so you have that option. if you turn up the boost naman you might have to address fueling too.
- Aug 2004
- 2,452
July 30th, 2006 12:39 PM #6Originally Posted by speedyfix
what i like about the Top mount is the response maybe better because there will be shorter piping as well as not interfere with the many auxiliaries at the front. but yes there's a problem on hood interference and will need some cutting and & scoop (i think i saw some of the fabricators in San Pedro Laguna).
July 30th, 2006 08:35 PM #7
ang prob nga kasi, pag designed ung turbo-diesel mo na walang intercooler, when you put an intercooler, the intercooler itself will made the forced air reduce/loss its pressure, intercooler itself is a air restrictor,e....
i'm planning to put one on my 2c-te liteace, front-mount or side mount (under my LHD sliding door entry) but, sa piping ako magkakaproblem...ang sikip!
sa piping palang lost na ung boost pressure, pano pa sa intercooler, at baka masmahina pa sa atmosphere pressure pag bumalik na sa makina...so consider mo din magpalit ng turbine for efficiency....
im also thinking if i use a more powerful turbine (so means bigger mass of air to the engine) for my liteace, without putting an intercooler, anu naman effect sa engine ko, without modifying the fuel supply
as for OEM surplus and fabricated intercooler and mounting, walang problem kang haharapin sa part na yun, ang problem talaga is ung effect sa engine...
- Aug 2004
- 2,452
July 31st, 2006 10:47 PM #8Originally Posted by alwayz_yummy
- Nov 2003
- 3,848
July 31st, 2006 11:18 PM #9if you don't mind cutting into the hood then you should have no problem.
August 1st, 2006 09:22 PM #10
it might be possible to adjust the boost via the blow-off valve (baka simple trick lang like the "washer trick" on the 4M40 pajero).
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
