Results 1 to 3 of 3
- Jul 2006
- 52
January 1st, 2007 10:36 AM #1Hi mga bossing! Kindly share your idea regarding the pros and cons of installing headers..also what is the best header configuration for SOHC engine...TIA! more power sa tsikot!
January 2nd, 2007 12:26 PM #2
Completely depends on the engine. Basically, most branded headers are better than anything you can have made at Nodalo's.
Pros - better throttle response, more midrange and high rpm power.
Cons - loss of low rpm torque (if your headers are too big), heat soak in the engine bay (cast-iron stock exhaust manifolds absorb more heat than they radiate, thin-walled headers can't absorb as much heat, and they just pass it straight into the engine bay unless they're ceramic coated or have header wrap).
- Jul 2006
- 52
January 2nd, 2007 12:35 PM #3ek ph16a engine...how about gas consumption?tnx sa reply...akala ko wla ppansin sa question ko =D
Heard through the grapevine that the Atto 2 is going to be released next. The most likely date is...
BYD Philippines
