Results 1 to 10 of 17
- May 2019
- 61
November 10th, 2020 12:45 AM #1Hello po again! Haaayss lagi na lang may problem
Help naman po, bakit po pag narereach ko na ang 16kmp/h biglang lakas ng shifting, no problem naman po onwards. Palagi ko lng naman pong na eexperience if mareach ko 16kmp is yung auto-lock..
I tried many times from 0 reaching 16 up, and yung mag shi-shift na xa ang lakas ng feeling, biglang alog.. but after nun wala naman na po IF not going below 16kmp
Also i tried turning off the car (Gilid ng highway) then start, going to 16kmp, biglang wala naman po! Then mamaya nabalik
Okay naman po atf kakapalit lang nung January sa casa, engine support okay naman po.
- Jun 2011
- 1,235
November 10th, 2020 08:46 AM #3
November 11th, 2020 03:17 AM #4
since you already had the transmission fluid done by casa, I think the next step is having it scanned. Maybe the 1st-2nd gear solenoid is not ok. in another thread here, i saw in the video that this solenoid is external, which is a good thing( repair cost will be lower)
- May 2019
- 61
November 11th, 2020 08:59 AM #5
- May 2019
- 61
November 11th, 2020 09:00 AM #6
- May 2019
- 61
November 11th, 2020 09:11 AM #7Just an update po!
Hindi ko na po ma experience yung issue, wala na ung nginig when reaching 16kmph. Been doing test drive kahapon, i also done the same scenario which is byahe from dasmarinas going to bacoor then stop for 10mins then uwi, but the issue didn't occur
Sabi ng pinsan ko monitor ko muna daw ng 1 week kasi lalabas at lalabas daw un. Haays, kung kelan ko pinacheck saka ayaw magpakita nung issue.. Iba talaga yung feeling, kahit todo apak ako sa gas, talagang hihinto at hihinto xa sa 16kmph then dun xa prang mabibitin (yung feeling na nag engage ung aircon pero masmalakas). Sabi niya, baka daw barado na ung transmission filter, so i will observe na muna.
November 11th, 2020 03:53 PM #8
- May 2019
- 61
November 12th, 2020 06:24 AM #9Bali, from 0 -15kph wala pong issue, pag nag 16kph na saka po xa parang feeling na naka manual ako na nag shift, parang may delay po pag dating ng 16kph then going more than 16kph wala naman na. Basta po, hindi talaga nag xa nag sskip sa 16kph kahit tuloy ang apak ko ng gas.. Dadaan at daan xa sa 16kph then dun ko ramdam ung malakas na shifting going up (Car is an AT). Di ko po kasi na test drive ngayon eh, may bagyo
Bali eto po yung gamit kong oil, for my Civic FD. Okay po ba yung oil na yan?
November 12th, 2020 08:19 AM #10
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
