Results 1 to 9 of 9
    Feb 2006
    My Civic after running more than an hour, my temperature gauge on the dash will suddenly spike to the maximum, yon talagang dulo ng gauge, lampas pa sa red mark, pero after 10-15 seconds, babalik sya sa middle ng gauge,
    Ano sa tinign nyo ang defective. the engine is not losing power naman. I already have a new radiator.looks ok naman ang cooling.
    I hope you can help me with this poblem. THNAKS!!!!
    brod, check mo ang coolant if coolant ok,try to bleed the air if no air check stat medyo mahaba ang process, dalhin mo na lang sa trusted mech mo para sa systematic diagnostics procedure...
    Nov 2003
    check the body grounds.
    Dec 2003
    check gauge itself maybe
    Mar 2005
    replace thermostat.
    Quote Originally Posted by mr._bator
    sounds like some air is inside your cooling system.
    Sep 2005
    check mo ung ground wire mo baka my maluwag or may naalis. poor grounding yan. hope this helps.
    Jan 2004
    try mo yung mga grounds. something like that. may kakilala ako sa speedometer naman, apparently, may nasira yata sa gauge somerwhere sa loob.
    Nov 2003
    it's probably not in the cooling system. it wouldn't make it erratic like that if you are really overheating. electrical yan.
HELP, Civic temperature gauge problem.
