Results 1 to 9 of 9
- Feb 2006
- 28
March 6th, 2006 10:42 AM #1My Civic after running more than an hour, my temperature gauge on the dash will suddenly spike to the maximum, yon talagang dulo ng gauge, lampas pa sa red mark, pero after 10-15 seconds, babalik sya sa middle ng gauge,
Ano sa tinign nyo ang defective. the engine is not losing power naman. I already have a new radiator.looks ok naman ang cooling.
I hope you can help me with this poblem. THNAKS!!!!
THE AUTO SPECIALIST
- Mar 2006
- 607
March 6th, 2006 12:34 PM #2brod, check mo ang coolant if coolant ok,try to bleed the air if no air check stat medyo mahaba ang process, dalhin mo na lang sa trusted mech mo para sa systematic diagnostics procedure...
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Mar 2005
- 703
March 7th, 2006 12:17 AM #6
Originally Posted by mr._bator
- Sep 2005
- 3
March 16th, 2006 10:58 PM #7Originally Posted by mr._bator
March 16th, 2006 11:07 PM #8
try mo yung mga grounds. something like that. may kakilala ako sa speedometer naman, apparently, may nasira yata sa gauge somerwhere sa loob.
- Nov 2003
- 3,849
March 16th, 2006 11:30 PM #9it's probably not in the cooling system. it wouldn't make it erratic like that if you are really overheating. electrical yan.
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
