Results 11 to 12 of 12
October 9th, 2006 05:24 PM #11
Mukang minor problem lang po yan. Ok din pa check sa Honda dealer, AFAIK, libre naman ang checkup sa casa. Medyo pricey lang siguro ang parts and labor dun.
Sorry po wala ako idea sa casa rates e, most of the time DIY lang ako dati.
- Oct 2006
- 43
October 9th, 2006 07:16 PM #12not sure kung applicable yung approach ko sa mga experts dito. but i check the belts kung may slippage by pouring a bit of water on it while idling (ingat lang sa tubig na magliliparan). pag nawala yung sound, belt slip yun. i think this is the easiest way to check.
kung sinasabi mo naman na lumabas yun after i-mount yung compressor, baka alignment naman nya yung mali, worth checking din.
kung grinding sound, baka sa ibang parts but most likely compressor bearing kasi yun yung sinervice-an. malalaman mo yan kung gagawin mo suggestion ni kups.
VinFast VF 3
