Results 1 to 9 of 9
- Mar 2012
- 1
March 26th, 2012 09:30 PM #1Good day po sa inyo bago lng po ako dito..May problema kasi ung driver side ng power window ko minsan ok sya minsan naman totally not function.Tapos kahapon po gumana sya pero maingay,now ayaw na po tlaga.Motor po ba and possible cause nun o fuse lng? Ung sa passenger window ok nmn po mabagal lang.Salamat po.
March 29th, 2012 03:06 PM #2
please identify your car. the most used window motor is the driver's window. in time, the motor's brushes wear out. also check for binding due to lack of lubrication on the window guides. if the p/w motor effort/load is increased, the circuit breaker built inside the power window package trips and you have to wait until it cools down to self resetLast edited by jick.cejoco; March 29th, 2012 at 03:09 PM.
- Sep 2017
- 2
July 29th, 2020 09:48 PM #3If you need power window repair, you can contact Ver at 09273246425. He also supports home service.
July 29th, 2020 10:42 PM #4
Sayang area ba sya nagse service?
Yung left rear ko, dahil Hindi halos ginagamit, nagulat na lang ako stuck na or ayaw na gumana
July 30th, 2020 02:06 PM #5
Usually yung power window motor lang yan. Pinagawa ko yung akin sa auto electrical shop sa Cubao area bumili lang ako ng replacement motor from Mazford for mazda 3 first gen. Madali lang palitan. Yung hindi madalas ginagamit mabilis din masira akin yung rear left. Ang symptoms nya tumitigil then may maingay na parang di kumakagat yung gear.
July 30th, 2020 04:48 PM #6
Ung sakin, walang noise, ayaw na talaga bumaba, don't know if stuck sa rubber seals or something or if sira na talaga motor, anyway pag pinagawa ko ganun ulit mangyayari, I won't use it ulit, kasi 3 lang kami madalas and the 3rd passenger seats on the rear right. And bihira talaga buksan, pag meron lang umutot. [emoji38]
- Jun 2005
- 3,772
July 31st, 2020 09:36 AM #7
- 52,729
July 31st, 2020 09:56 AM #8i regularly play with all my power buttons, to exercise the mekanismos.
that kinda ensures that no stuck-ups due to non-use, will occur.
- May 2019
- 312
August 12th, 2020 05:37 PM #9If the other side is also acting up, most likely you need window regulators on both sides.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
