Results 1 to 5 of 5
April 9th, 2008 06:18 PM #1
Mga experts ask ko lng opinion nyo bka may naka encounter na sa inyo pa share na lang possible solution to my prob,
anyway nag pa change oil na ako check sparkplugs and ATF ok naman lahat, nagpalit na rin ako ng timing belt, oil seal, tensioner bearing, power steering belt and alternator belt pinalinis ko na rin un Servo dahil medyo mababa na un idling ko (around 500rpm) pag nka a/c ko tapos naka drive un tranny ko while my feet is on the brakes.
ang prob ko nagyon pag naka a/c na ako and naka drive un tranny ko while pressing the brakes namamatayan ako minsan nga hindi pa ako naka full stop mdyo mabagal lang andar ko example while nag papark at naka bukas pa rin a/c ko namamatayan na rin ako, pag off ang a/c wala problema ok naman lahat.
in addition to that mga couple of months ago inadjust ko un idling tinaas ko ng konti so lagpas ng 1000rpm ko pag naka neutral ko with a/c is off, pag naka on un a/c nasa 800rpm naman sya. adviceable ba un ginawa ko?
please let me know your comments.
thanks...
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 13th, 2008 04:55 AM #2could be pasira na servo. or maybe mali adjustment na ginawa for the car.
- Dec 2009
- 7
January 7th, 2011 04:19 PM #3I-bump ko lang po ito because I have exactly the same problem. 2002 lancer. Thanks in advance.!
- Jul 2003
- 573
January 7th, 2011 06:32 PM #4you need to bring the car to a good auto technician with proper diagnostics tool or expertise for that type of problem
January 7th, 2011 06:59 PM #5
