Results 1 to 8 of 8
May 7th, 2005 03:04 PM #1
Guys, please help me diagnose the problem on my car. When im on REVERSE i can hear a (clak, clak, clak) sound on the engine bay area of my car-90 corolla gl. Though the sound is not constant, it's more pronounced on uneven/rough road, but not present when the car is on forward direction. I've already changed the shocks. I suspect the CV joints, ball joints and bushings. What do you think?
- Nov 2004
- 78
May 7th, 2005 04:13 PM #3Try to have someone checked your engine support. Same thing happened to me with my GLi. Found out that 2 of my engine support had cracks.
May 9th, 2005 09:16 AM #4Originally Posted by conzky
May 9th, 2005 12:35 PM #6
better yet punta ka na kay Sir Toti (Zee) expert sila sa mga ingay na ganyan!!!
May 10th, 2005 07:10 PM #7
Hi guys, thanks for your replies. I checked the engine supports and one of them has a crack alright, but granting its the one that causes the noise, why is it that it only occurs when Im on reverse?Thanks in adavance, again!
May 10th, 2005 07:41 PM #8
i had the same problem. the reason why it only makes noises when reversing is that the stress is concentrated on the engine support that is weak and therefore, foreplay of the mounts is more prominent on the broken support, thus making noise while reversing....hmmmm..did i write that correctly...hehehhehe
Hybrids and EV
