Mga guru's, My ride is nissan eccs.. Ano po mas recommend at subok nyo sa dalawang oil(Castrol GTX 10W or Shell Helix Blue 10W) na mas maganda at have a great performance. Magpa change oil po kasi ako sa Monday.TnX
wala naman castrol na 10w.. 20w-50 ang alam ko gtx.. pero ako gamit ko shell 10w-40.. ung kulay blue container
Sir, merun po na Castrol GTX 10W-30. Sir, ok naman po ba performance sa inyo ang Helix Plus(Blue)?? tnX sir.
i would go for the shell blue, i've used it years back. i have some not so good experience with castrol.
but if i were you i would go for mobil semi-synth.
Sir, kaka pa change oil ko lang, i Used Shell Helix Blue. Pag drain, halos super color black na pala engine oil ko, hindi na ginamitan ng engine flush nang mekaniko, Ayos lang po kaya iyon na hindi na nya ginamitan engine flush ehh paglabas nung oil super itim???
^^ no need to use engine flush, it's a waste of money,
kung gusto mo talaga i-flush, instead of waiting for the 5000 kilometer change oil interval, palitan mo na pag hit ng 1000 palang or earlier, put in a new set of oil, then go back to the 5K kilometer interval.
i've been using the castrol magnatec for over a year now & so far i haven't had any of its infamous sludging issues. but the next time around i'm planning to use the eneos 10w-40 semi-synth blend. it's not very popular here but i've heard it has a very good rep abroad![]()
Yung sa 5th Gen Accord ko din Magnatec. But when I had some things fixed over at Speedyfix last year, nung tinanggal yung valve cover, nakita namin na may varnish na. Don't know kung after-effect yun ng Magnatec, kasi 2nd hand ko nabili yung car.
But it works for me. Semi-synth na sya for less than 260/liter.
kung semi syn, depends kung saan mo pagagawa kung sa shell, free labor if you choose shell products or even dala mo from suking auto supply as long as it's shell. If DIY any of the two.
but IMO kung not strictly specified ang semi syn, I would prefer pure mineral based and change it at 4000 kms, more cleaner and much fresher ang engine mo everytime at a lesser cost.
Ok naman Shell Helix Blue. Gumanda hatak auto ko. Im using V power as my fuel. 9km/L na ngaun.pwede pwede na
mga expert,
question po. sa leaks, would it make a difference kung 20w-50 ang gamit ko? i'm using mobil 1 5w-50. o pareho lang ang bilis nung dalawa tumagas?
i am considering moving to mineral oils; castrol gtx 20w-50 ang balak ko gamitin if ever... tia.![]()
if you are more concerned with leaks, get the one with higher viscosity. in your case, mineral should be fine.
mGa sir newbie lang po me.... im just wondering what is the difference of MINRAL OIL to FULLY SYNTHETIC OIL.... and what are the PROS and CONS. of this two OIL... I have a TOYOTA 3T enGine.... and im planning to change my oil this coming january.. give me some advice if what kind of oil im using....
thanks in advance........
LOVE ALL... mwhaaa!
theres lotsa info on the net about the differences. google is your friend.
