Results 1 to 10 of 17
November 7th, 2007 11:53 AM #1
Hello mga fellow tsikoters..
Last 2 weeks ako nag pa overhaul ako ng carborator ko then palit air filter, sparkplug and fuel filter nadin..
after matapos na lahat ok na..then pag uwi ko then overnight parking, kinabukasan pag bukas ko ng door ng otobot ko...amoy gas...
hinde ko naman alam kung pano nangyari nun..
may feeling ako na baka sa fuel filter yung may tagas???
any feedback will be greatly appreciated...pano ko kaya matatangal yung amoy..
kakahilo kasi eh..
Thanks for reading these..
November 7th, 2007 12:30 PM #2
Check under the hood. Most likely may leak yan somewhere within the engine bay itself ..
November 7th, 2007 12:52 PM #3
Baka may na-spill ng gas sa pagpalit ng fuel filter. If the smell doesn't go away, check for fresh leaks and re-tighten the hoses, as necessary.
November 7th, 2007 03:05 PM #5
Check kung malinis pagkagawa sa repairs. If not, correct this problem. Clean the surrounding areas first, avoid driving the car baka may fuel leak and the heat from the engine will cause a fire to start.
- 150
December 10th, 2007 02:43 PM #7singit po ako mga boss, sa akin naman po, sa may front passenger side na wheel well, sa may engine, amoy gas pagkatapos magdrive, pagpark usually amoy gasolina po. sa driver side naman po wala naman. normal po ba yun? ano po kaya problema? TIA!
December 11th, 2007 03:18 AM #8
BANNED BANNED BANNED
- Jan 2003
- 23
December 11th, 2007 03:29 AM #9Note that your post would do more harm than good.
December 11th, 2007 04:15 AM #10
