Results 11 to 17 of 17
- Feb 2007
- 60
February 21st, 2008 02:24 PM #11To the experts, hope I can have your inputs on this...I am having an almost similar problem.... Nag-aamoy gas sa loob ng car pag pumalo ng 60 kph and up. After a few minutes, nawawala naman. Kakapalit ko lang ng fuel filter, nilinisan ko rin ang plugs, change oil last month, carb overhaul 2 months ago... Ano kaya ang probable cause nito?
February 21st, 2008 02:48 PM #12
60 km/h and up, regardless of engine speed? Or only at higher revs?
If it's at higher revs, it's possible your jets are basically dumping fuel into your engine. I'd have the carburator inspected again... might be something loose.
- Feb 2007
- 60
February 21st, 2008 03:13 PM #13
February 21st, 2008 03:37 PM #14
kapag pinatay mo ba ang makina ay kinikilig ang makina mo?
madalas kasi mangyari yan sa mga carburated engines, sumisingaw yung excess gasoline sa loob ng carb kaya nangangamoy. isang cause din ito kapag naka-advance ang timing ng engine mo.
- Feb 2007
- 60
February 21st, 2008 04:28 PM #15
February 21st, 2008 06:13 PM #16
first thing, alam mo dapat kung ano ang tamang timing ng makina mo, meron degree na sinusunod dyan. using a timing light din para makita yung marker sa crankshaft pulley.
subukan mo rin na huwag muna ipatay ang engine after a long trip (count to ten ka muna) para magnormal lang ang engine idling (parang concept ng turbo timer ba). after 10 sec. mo i-switch off, observe mo kung may amoy gas ka pang maamoy.
carbed din kasi oto ko, meron time din na amoy gas after switching off the engine, pero hindi madalas.
- Feb 2007
- 60
