Results 1 to 13 of 13
    I'm not sure what's wrong, but my passenger door lock won't open... If I try to open it manually, it's a little stiff and it relocks itself... When I use the power doorlock switch from the driver's side or the key, ganun din, it opens 3/4 of the way then locks again.
    If I try to manually hold the door lock open then pull the door handle, it won't open coz the lock hasn't disengaged yet.
    Now I can't open the passenger's door at all, so kung sasakay ka dun, sa driver's side ka dumaan hehe.
    How can I fix this if I can't even open the door itself to remove the sidings :P
    I've thought about disconnecting the battery to disengage the power sa actuator, but haven't had the change to try it yet...
    Hassle :P
    Sep 2005
    try mo sir spray with wd40? baka na stuckup lang.
    Jan 2004
    This sounds awfully familiar, parang nangyari na sa akin ito...
    I think someone had to manually disengage the lock from outside.
    Then replace the actuator once open.
    merun tumutukod sa lock mechanism ng door...likely the actuator nga. Try the remove battery connection option. Hopefully ay mag-disengage yun.
    You can try removing the upuan sa likod para maaccess or makalas ang door cover....matrabaho pero meron ka namang tao sa shop to have it removed (rear upuan) di ba?!?
    had that problem before on the rear left passenger door, baklas sidings and spray ng sangkatutak na WD40, nag-okay naman after, but it's still a little stiff/stucked opening it, pero nabubuksan na.
    I sprayed the WD40, on the lock mechanisim itself, the door handle, and all the springs or mechanism na makita ko within the vicinity of the door handle and door lock.
    HTH
    Quote Originally Posted by artpogi View Post
    HTH
    same here. right rear passenger door naman. ako na rin mismo nag baklas and nakaubos ata ako ng almost isang lata ng WD-40. tapos nun ok na.
Passenger door lock won't open
