Results 1 to 18 of 18
    Jan 2004
    Tanong ko lang kung anong effect kung pinaputulan ko lang ang springs rather than buy a lowering kit para sa pa-lowered ng auto? i mean, lowered ang look, but how about the performance and effect nito sa suspension ng auto? - pizza pie ang auto.
    Three Words:
    [SIZE=4]DON'T DO IT!!![/SIZE]
    remember these words...
    "save some money now... pay a lot more for repairs and proper lowering springs later."
    please repeat 3 times...
    save up man..
    its worth it...
    i mean the lowering springs... the real one.. not the cut ones
    ito lang masasabi ko..do it right the first time ;)
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Jan 2004
    actually I cut them already.. It was just I thought about it when a friend told me that I should have not cut 'em because of the things you mentioned here. I guess it's too late (I wasn't able to log here for several days -- bad trip, naka-block and yehey sa client namin and no phone lines to use for dial-up hmp!)
    Anyway, I don't have that much experience yet on seeing/feeling kung masyadong matagtag ang auto. On a straight, fine road okey naman.. so I assume so far, so good. My only indicator would be pag bumigay ang shocks (kapapalit ko lang last week nung isa just before I decided to cut 'em). So when that happens, then mali na nga.
    Any suggestions kung anong magandang brand ng lowering springs (or pare-pareho lang ba ito, brands lang nagkatalo)? and saan makakabili nito? I wanted to buy them myself para alam ko.. saka pano mo malalaman kung peke or totoo?
    Thanks in advance.
    Aug 2003
    you can't miss with Eibach.
    they're not too expensive, maybe 30% more than OE springs.
    Eibach Sportline springs.
    dame brands dun.. sheepdog o b+g
    merwede rides good on the pizza pie of my friend..
    Nov 2003
    if you want merwede give the shop a call
    7237625
    Dec 2003
    Ask ko lang since car ko ay maliit lang like the starlet paano kung madami pa ikot ng springs mo?...Hindi pa rin ba tama ang pagcut ng spings kahit na marami pa ikot ng springs mo?.Base ko kase sa kapitbahay ko na corolla 1 cut din yung kanya...
    Anyone here knows a lowering springs for small cars? Kahit mahal ok lang sa akin...:D
    Apr 2004
    Dont do it pre... i did it b4 sobra tagtag and u can't even have a normal load, sumasabit kaagad. Lowering springs costs between 8,500 to 11,000 lang pre. Sa kontng halaga pre buhay ang kapalit... hehehehe... your car won't be that stable spec. when cornering. I suggest you use a lowering spring. If you're interested in purchasing one tx me * 09178474315. 8,500 lang yan isang set.
    Jan 2004
    thanks speedy, actually, you gave me a quote already.. akala ko nakatipid ako sa putol eh.. now, too late.. im trying na lang to be careful sa mga lubak (lintek). ipon muna ng pondo... may bawas pa ba yung merwede mo speedy? would the cost cover the installation already?
    Jan 2004
    definitely a big NO-NO!!! you'll ruin your car. stocks springs has a specified spring rate, thus reducing or even cutting the spring for vanity (porma) will only result into a harsher ride, in worst case, can cause problems later on. you can always buy aftermarket kits, just don't cut your springs...
    thanks!
    h&r springs ang gamit ko sa pizza pie mitsu ..
    super dooper sarap ng ride. very comfy...kahit malubak ndi ka matatakot magsakay ng buntis na malapit ng manganak.
    rides wayyy better than stock..im still using oem springs though ndi pa ako nagpapalit..wear out ko muna bago ko palitan
    Apr 2004
    mgbrillo ikaw ba si mark brillo? dating programmer sa easycall?,.. kung ikaw nga eh si Oliver ito. alam mo naman yung ride sa dati kong kotse eh matagtag at pumapagpag sya at delicako sa corners kase grabe sa understeer.
    ngayon lang ako ulit nagcheck dito sa tsikot.com, nakalimutan ko na yung login name ko. kelan kayo pupunta dito ni misis mo?.
    pare magtabi ka na ng pambili ng shocks.
    email mo ko dito omllenado*msn.com
paputol ng springs for lowered look?
