Results 1 to 10 of 11
Threaded View
December 14th, 2004 05:49 PM #2
depends on your engine. check your user's manual for the optimal oil weight to be used in your car.
for example, the the rav4 1.8L 1zz-fe engine's optimal oil is a 5w-30. while the rav4 2.0L 1az-fe engine's optimal oil is 10w-40.
to determine your the optimal oil, check which oil has the broadest / widest coverage of temperatures. though you can safely rule off temperatures of below 0 deg C here in our country.
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
