Results 1 to 10 of 11
- Sep 2003
- 52
December 14th, 2004 05:43 PM #1Which of the two engine oil rating has the best protection under Philippine road condition?
Both will be Fully Synthetic in nature...
December 14th, 2004 05:49 PM #2
depends on your engine. check your user's manual for the optimal oil weight to be used in your car.
for example, the the rav4 1.8L 1zz-fe engine's optimal oil is a 5w-30. while the rav4 2.0L 1az-fe engine's optimal oil is 10w-40.
to determine your the optimal oil, check which oil has the broadest / widest coverage of temperatures. though you can safely rule off temperatures of below 0 deg C here in our country.
December 14th, 2004 05:55 PM #3
i'd go for 5w30 or 10w50 if available. mainit dito kaya di syado recommended low viscosity oil afaik.
- Sep 2003
- 52
December 14th, 2004 05:58 PM #4Mazdamazda, My ride is an altis 1.6 3zz-fe. Im planning to get Mobil1 Supersyn 0w-40 or Castrol Syntec 5w-30. Dont know which of the two is better. Both will be Fully Synthetic in nature.
Which will you choose?
Tsikot Member Rank 3
- Dec 2002
- 636
December 14th, 2004 07:17 PM #5Aside from what was mentioned above, you can ask what the toyota dealers use for synthetic oil. Think the toyota synth oil is a 5w40.
My suggestion is to use a 5w40 or 5w50 or 10w30 full synth. Don't think castrol Syntec is a true "full synth" oil based on comments from the oil forums.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 28th, 2004 10:05 AM #7
Originally Posted by hytan
if you want better gas consumption - i'd go with the 5w-30. i think that the zz series engine is designed to handle 5w-30 (unlike the az series).
but if you plan on keeping your ride for a LONG time, go with the mobil1 0w-40 (what am using right now). toyota shaw-ortigas uses that kind of full-synth oil.
- Sep 2003
- 52
December 28th, 2004 12:19 PM #8I'll be using Mobil1 sa ZZ engine ko. Mas may tiwala ako kay Mobil1 0W-40 rather than Havoline Energy 5W-30 because im planning to use my car a long time.
December 28th, 2004 01:14 PM #9
Here's some excellent accurate information about oil:
http://forum.e46fanatics.com/showthr...ighlight=0w-40
I would recommended Mobil 1 "0w-40".
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
