Results 1 to 19 of 19
    Aug 2007
    Hi Guys, need your expert advise. I've noticed that whenever i happen to follow smoke belching vehicles, I tend to smell it inside my Mazda 3 even if my windows are fully closed and aircon switched on. Do I need to correct something here? Its basically a new car so it should not be the case especially that as far as I understand the interior should be sealed. Appreciate the help. Thanks
    baka naman naka-open ang vent ng auto mo...this the switch near the a/c thermostat - usually it should be circulate mode and close ang vent. kung nakaclose naman ang vent, baka sira ang fitment ng vent cover.
    Aug 2007
    Hi Thanks, when you say it should be on circulate mode (this is the switch with a circular arrow?), this should be turned on? When you turned it on, ibig bang sabihin close na ang vent? Where should I locate the fitment ng vent cover, if this is the case... Sorry for the numerous questions...
  4. #4
    read the manual po.... ksama yan sa aircon dials--. if the arrow forms a cicle, dapat nandun ang set/nakatutok ang color ng dial/lever, not yun arrow na parang galing sa labas...
    1 time pa lang nangyari sakin ito. Sobrang kapal lang cguro nun usok na un. Madalas naman hindi.
    Aug 2007
    I'll try to observe again baka nga, case to case basis or the circulate switch is turned off. Thanks again.
  7. #7
    kung may prob, claim for warranty..
Outside smoke penetrating inside Mazda 3
