Results 1 to 14 of 14
    Apr 2004
    pwede ba naman mamatayan ang car na automatic ang transmission?? akala ko dati impossible!! pero pwede pala!! kainis yun mazda 323 ko nagfluctuate nanaman yun rpm... dati hindi ito ganito pero for the past two years naging ganito... tapos minsan namamatayan pa ako pagnakahinto... lately kahit umaandar biglang mamatay... nawawalan ng kuryente... gusye help naman ano kaya problem nito?
    Clogged fuel filter? Or contaminated fuel inside your tank.
    Apr 2004
    thanks... paano ko malalaman kung contaminated yun fuel? paano palinis?
    Drain all your fuel and check visually, ginagawa ito sa mga gas stations kung san maraming lalagyan para sa aalisin na fuel sa tanke, which is 45 liters or more when full.
    i agree.. possible clogged fuel filter, fuel lines.. not enough gas is getting to your engine... possible din na bad batch of fuel.. for the past 2 years ba you've been getting fuel in only one station??.. if so.. change station.. if not.. then you might have some water contamination inside your tank.. and kahit san san ka magpakarga.. kung nandun sa tanke mo yun... talagang mangyayari yan... EFI ba yan??.. baka yung fuel pump mo ang may topak...
    check your fuel system... get a tune up.. possible din na your idle is not up to spec and that you have a problem with idling.. causing your car to die down.. pag nde ka naka-ac nangyayari ba yan?.. what are the circumstances na namamatay ang makina?
    Clogged fuel filter din ang problema ko sa Benz dati. Madumi lang pala yung tank. Afterwards, ok na.
    Mar 2004
    try mo palinis or pacheck yung Cervo kit baka yun yung may problem
    Apr 2004
    pag-naka a/c namamatayan pagpinatay tumataas yun idling... magkano magpalinis ng fuel system? saan maganda?
    Idle up vaccum may problem kung on ang aircon at namamatay. May tagas ang linya ng hangin papasok dun. Or if your vehicle has computer chip, merong isang part yung ECU yata yun, di na gumagana.
    Maraming pwedeng factors on that. I've also experienced that once on our old 323 before. Same thing happened recently with our Cefiro (which i think was because of a bad load of gas).
    Start with the basics. If you have not changed your fuel filter, change it and check your spark plugs/ignition system as well. Then move on to the other possible parts (Vacuum lines, sensors, etc)...
    Nov 2003
    the best thing to do is to remove the whole tank, drain the gas then clean the inside. you'll be surprised how much gunk is there.
    you may also want to check the different vacuum lines.
    speedyfix,
    is it really necessary na magpalinis ng gas/fuel tank ang mga newer cars after sometime? may nakapapsabi kasi sa akin na ang mga dapat lang nililinis ay yung mga old diesel cars na metal pa yung tank... yung mga newer cars raw kasi plastic na ang tank...
    if yes, how much po singil niyo sa pag linis ng gas/fuel tank and fuel lines ng 1997 Toyota Corona Exsior?
    gaano po katagal na trabaho ito?
    what's the name, address and contact no. of your shop?
    thanks!
    un sa frend ko nakagalant pag naka D lang bago nagflufluctuate.. pag R hinde naman.. bakit kaya?
    van_wilder,
    try bringing it to prince motors..
    punta ka rin sa http://www.protegetech.org/forums
    we can help you there.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
namamatayan na matic
