i agree.. possible clogged fuel filter, fuel lines.. not enough gas is getting to your engine... possible din na bad batch of fuel.. for the past 2 years ba you've been getting fuel in only one station??.. if so.. change station.. if not.. then you might have some water contamination inside your tank.. and kahit san san ka magpakarga.. kung nandun sa tanke mo yun... talagang mangyayari yan... EFI ba yan??.. baka yung fuel pump mo ang may topak...
check your fuel system... get a tune up.. possible din na your idle is not up to spec and that you have a problem with idling.. causing your car to die down.. pag nde ka naka-ac nangyayari ba yan?.. what are the circumstances na namamatay ang makina?
