Results 1 to 10 of 13
September 6th, 2005 10:24 AM #1
Im puzzled!!!Since the last time i changed oil, i noticed that my engine oil level is above the normal. At first, I thought i just overfilled my crankcase, so i drained the extra oil to make it to exact level. It was 1 and a half weeks ago today. when i checked this morning, the oil level is again higher than normal. Can you please enlighten me on this? Thanks in advance.
- Jul 2005
- 83
September 6th, 2005 10:52 AM #2gasoline or diesel engine?
color of the oil?
is the car on level ground before checking the deep stick?
did you check it before sarting the engine?
September 6th, 2005 11:08 AM #3Originally Posted by jeegoogs
reddish black
garage is more or less on level ground
oil was checked before starting
- Jul 2005
- 83
September 6th, 2005 11:40 AM #4what's your ride? engine?
Have you experinced overheating before? or major engine repair?
probable cause - fuel leakage from the fuel pump seals
- water leakage from the head gasket
September 6th, 2005 12:14 PM #5Originally Posted by jeegoogs
havent experienced overheating;
and no major repairs done so far;
i guess fuel leakage is most likely the cause;
i think there's no water leakage, since the color of oil is normal, in such case, the oil color should have looked like milk.
BTW, how much is the cost of fuel pump nowadays?
thanks for the input sir.
- Jul 2005
- 83
September 7th, 2005 08:59 AM #9Originally Posted by conzky
I don't know the exact price but most likely around 2k - 4k sa brand new replacement parts.
wag mo na gamitin ung ride mo ksi it could cause a crankcase explosion due to gas vapor inside. Accessible naman ang fuel pump ng 5k,3 bolts lang ata ang tatangalin para mahugot yan.Kaya mo gawing mag isa then bring the sample.
Or bring your ride to a shop nalang to make it sure.
September 7th, 2005 10:22 AM #10Originally Posted by jeegoogs
From what I have seen, some premium/performance makes, like BMW, suggest weights(sand bags) on...
Wheel Alignment
