Results 1 to 6 of 6
July 29th, 2009 02:13 PM #1
just this morning, namatay o hindi na gumagalaw yung odo ko tsaka yung km. reading part ng speedometer ko (yung part na pwedeng i-reset), although yung speedometer ko naman is buhay.
saan kaya problema nun? i had the thought na isang cable lang naman ang nagpapatakbo ng speedometer and odometer eh.
pwede kaya ayusin yun ng DIY? analog odo nga pala and the car is B14 Sentra.
July 30th, 2009 07:43 AM #2
Depends on if you have an electric speedometer or a cable-speedometer. If it's a cable one, check the cable if they are loose or bust. If it is an electric one, maybe a bad sensor or wire - start by checking your fuses and if they're okay then check the wiring. Replace the sensor if you have to.
July 30th, 2009 01:38 PM #4
*afrasay, if you say the cluster, eto ba yung nasa loob ng engine bay?
*v6: its cable type, i assume. analog speedo lang. i think walang sensors involved dito.
July 30th, 2009 03:09 PM #5
It's a gauge problem. TS says that the speedometer is still working and only the odometer and trip meter aren't moving. Since it's analog, it's very likely that it's a broken gear or another mechanical part inside the speedometer gauge.
DIY: The gauge can be taken apart and checked if the broken part(s) can still be repaired. If not, buying surplus is your next best option. Just make sure to copy the odometer reading from the old gauge to the new one.
- Jun 2009
- 325
July 30th, 2009 04:39 PM #6Have the spedometer assembly check by a skilled mechanic. The odometer is no longer running. That could be repaired since it is mechanical type with small plastic gears inside. I already encountered that same trouble before on my 92 Super Saloon and repaired by my cousin who works with a local Nissan dealer before.
Working na MMDAs. MayHulika. Only for NCAP violations
SC (temporarily) stops NCAP
