Results 1 to 11 of 11
    guys,
    I will be out of the country for 4 weeks and walang gagamit ng car ko...wala rin pwede mag-start every morning...ok lang ba sa engine yun? also, di kaya ma-oblong yun tyres ko?
    thanks for your feedbacks.
    when i went out of the country for a month before, wala ring gumamit ng car ko, at wala ring nag-start, pero nung pagbalik ko, ok naman.
    as to the tires, di naman sila ma-oblong.
    Kung 1 month lang OK pa siguro.. sakin nga 2months ok lang,, every week lang start
    tanggalin mo lang yung battery terminals para sure.
    if paranoid you could also get a set of jackstands to lift your tires off the ground.
    wag mo tanggalin yun battery terminals, e di wala na alarm.
    ok lang yan, ako every month din umaalis, 1 month din ako wala. ok lang naman battery saka tyres.
    ang masama kung gaya nung sa friend ko, vr4 na galant e sa condo nakatira sa may likod lang ng shangrila. e di lakad lang nila ang megamall etc. so minsan 6 months nya di ginamit kotse yun palit sya ng gulong at nag-crack na yung rubber hehehe. ngayon naka jack stands na. di pa rin nya ginagamit kaya kahit na 5 yrs old na kotse nya di pa umabot ng 20,000 kms! sabi ko nga bilihin ko na lang e hehehe, ayaw naman.
    1 month is OK...
    - change the oil and filter (if it hasnt been done recently) so there wont be muich dirt and sludge inside to settle.
    - top up on gas before you leave it.
    - You may not have to jackstand the car but fill up on air to around 33-35psi cold (and make sure tehre are no leaks).
    - It would also be a good time to wash and wax before you leave the car. Clean the interior and engine bay as well.
    - put some rat poison also in the area near the engine bay or in your garage to prevent the rodents from building a nest in your car
    isa ring option nyo sir is to have your car parked at MIA Caltex - Park 'n Fly...malamang meron silang packages para sa car maintenance....
    Um, iwan mo sa MARC Caltex sa Pedro Gil.
    he he pwede rin...pa-undercoat nyo na rin he he(dami na ako utang sa tsikot...panay plugging :p )
    is Park & Fly safe to leave your car and how much do they charge for a typical sedan?
not using your car...
