Results 1 to 20 of 60
    Sep 2005
    arrrrgh....
    sunday nyt, along mandaluyong, brngy addition hills (market)..
    flood was knee deep, driving a honda city, placed the car at reverse and hazard but inconsiderate drivers at my back didnt want to move back, thus i was forced to go forward,,
    car is honda city, ayun, nilusob ko sa baha..
    are there any effects? mejo umusok ang hood, i assume its bec water penetrated the engine. mejo mababa pa naman ang clearance ng honda city. what are the consequences for this? if there are, will it be covered by warranty?
    after the flood, went to shell sa shaw (near kalentong) and revvd the engine a couple of times, to dry any left water. i hope that helped.
    Jan 2003
    afaik, damage caused by flood isn't covered ng warranty. sa mga special insurance companies, i think they do. anyway if flood water didn't seep into the cabin, safe na ang ecu mo. 2nd is do a check on the engine and transmission oil if pinasok ng water. pero it would be most unlikely. better be safe than sorry.
    Sep 2005
    yikes!!
    it can go that bad? ecu is safe, but i noticed dat my car isnt that smooth anymore, humina ang hatak or maybe im just paranoid. wla naman maingay sa makina and transmission.
    how do i have this check? have to bring it in casa? do u have any idea on how much they will charge for this?
    thanks for your feedback..
    May 2005
    Quote Originally Posted by Viper View Post
    yikes!!
    Make sure you have your cit gets underside greasing asap. Better yet, have the casa or other trusted establishment check on your ride. Explain the situation fully to them and have them give you an assessment/estimate repair cost first before proceeding with the actual service or repair.
    A mechanic once showed me that the aircon compressor of the city is located very low in relation to the ground.
    Jan 2003
    ...panong mahina hatak? parang sliding clutch?
    Aug 2006
    Modern cars have tons of wiring harness and sensors.Never try to do that stunt again.Check your MAF sensor.
    Oct 2003
    please correct me if i'm wrong pero hindi na ata nag-g-gresing sa ilalim ng kotse. puro assembly at sealed parts na kasi ang mga nasa pang-ilalim ng kotse.
    noong 1970's at early 80's uso ito though.
    Is your City a matic? Not sure lang with the City, but in some cars the dipstick for the ATF is a bit low. If the disptick is loose or gets loose from the floodwater, water may enter and mix with the ATF. Check if this was inabot. If you suspect inabot, tapos loose pa yung dipstick, have the ATF changed na rin.
    Jan 2017
    Ako lumusong pero wala naman akong nramdaman na pagiba sa takbo. Should i still be worried at ano parn mga dpat icheck ko?
    Sep 2014
    Quote Originally Posted by Kimchijiji View Post
    dumidikit kaya ihi ng daga sa gulong?
    From FB
    And another one swims the flood...
    A rover in the river...
    Comments
    Bagal ng patakbo niya imho. Pero kung hindi niya kabisado taas ng tubig hindi dpat siya lumusong.
    Comments
Baha--knee Deep
