Results 1 to 12 of 12
    Aug 2010
    i was driving last night and it was raining. suddenly the headlight and wiper stop functioning. pero yung pinitik ko yung headlight... gumana yung wiper (1x). so kung kailangan ko ng wiper, pipitikin ko yung headlight. i thought fuse lang ang problem. pinalitan ko lahat ng bago pero wala parin.
    what do you think is the problem?
    di kaya sa wiring na yan? may short. pa check mo kaagad sa electrical shop.
    Oct 2011
    check mo uli ang fuse sa headlight.better kung pa check mo na sa electrician.
    Feb 2009
    Quote Originally Posted by trucker111 View Post
    ano ano ang pinalitan mo. enumerate and describe
    what is your car make, model and year of manufacture?
    Jan 2009
    Pinipitik mo yung actual headlight or yung headlight switch?
    Kung yung switch, more likely yung headlight and/or wiper switch stalk may problem.
    Aug 2010
    pinalitan ko lahat ng fuse. all new.
    pinipitik ko yung switch ng head light para mag work yung wiper (1x).
    btw, before i drove it last night... mga 1 week kong hindi ginamit. nasa garage lang. yung paglabas ko ng garage ok pa. then i noticed na wala ng head light tapos wala na rin yung wiper.
    Jul 2011
    may nag short lang yan sa wiring palagay ko
    na-check ba yung mga fuses kung meron busted?
    Oct 2009
    Light bulb could busted?! Grounding wire is not good.
    Aug 2010
    i went to this auto electrical shop and explain what happened. the electrician assigned to me just knew what to do. he told me that "sunog yung mga cable mo". the solution is to rewire and add relays to the headlight and horn. he also advice me not to upgrade headlight bulbs to 100w w/o relays even in brandnew car. he also upgraded the plug of the bulb to ceramic. it is very important to let the professionals do the rewiring. hindi pala yan basta basta.
    Yep, which is why for plug and play solutions, it's recommended to go for bulbs which have higher output despite having stock wattage.
    Am personally using the Osram Nightbreaker Plus. Way better than stock
    Aug 2010
    the electrician installed 2 relays for my headlight. 1 for dim and another for high.
    btw, he advised me not to go beyond 100w. fyi
No headlight and wiper... Help!
