Results 1 to 18 of 18
    What can I use as power steering fluid? I'd like to have the system flushed sana as well as all my other oils. San ba marunong or magaling gumawa nito?
    Any powersteering fluid that meets DEXRON type II specifications will do.
    ano ba mga sample nyan?
    yun bang ATF sa shell , yun nakalagay sa yellow container ay pwede??
    o kaya yun STP power steering fluid? pwede na ba yun?
    Quote Originally Posted by boybitz
    May I remind you that when the PS pump gets dry this will cause its breakdown. You might want to exclude the PS fluid when flushing. As I know of, any ordinary ATF oils can be added to your PS reservoir. :D
    Quote Originally Posted by Ungas
    mr ungas is correct. exclude mo na lang flushing dahil it will create more damage sa power steering mo. anyway, power steering fluids don't need to be flushed or cleaned dahil malinis naman yung system nyan.
    any ordinary ATF oils can be used as PS fluids. this is useful kung AT yung car mo so that isang bilihan na lang. kung car mo is manual, i would suggest using a separate PS fluid.
    boybitz:::ATF lang po. I buy from petron. flush your system using ATF too.
    Yup, ok ans STP at Shell. :D
    meron din po ang Caltex: Caltex ATF-HDP
    Special purpose heavy-duty transmission fluid series designed for specific automatic and powershift transmissions and power steering system applications over a wide temperature range. Recommended for applications where the now obsolete DEXRONŽ-IID is required. Also for use in hydraulic systems and compressors which normally use such fluids. Specific approvals are Mercedes-Benz Sheets 236.1, 236.5, 236.6 and 236.7, Voith G.607, ZF TE-ML 3D, 4D, 14A and Allison C-4.
    Puede ba yan sa mga Honda cars?
    boss chieffy, pwede ba yan na transmission/gear oil sa akin? manual kasi kotse ko and balak ko din sya ipaflush. car is 99 lancer glxi.
    saw a bottle of shell power steering fluid, yung nasa yellow container nga sa ace hardware. Can't remember na how much. I'll get that na lang unless meron akong makuha sa caltex na pwede din na gear oil.
    Pwede pa pag halu-haluin yung power steering fluid?
    pano po pag gusto kong gumamit ng synthetic power steering fluid? D ko din kailangan iflush? just add lang?
    Like sa engine, if you use synthetics go all the way. Same goes to for mineral base PS fluids.
    so if there's really no problem w/ the steering wheel assembly and its fluid (no leaks), no flushing or replacing should be done? even if the psf is already dirty and if the psf has never been replaced in the car's entire lifetime?
    i'm asking this because i'm planning to have my car's psf changed/replaced. btw, the car is an ek 96
    Aug 2005
    We have an Altis, and according to the manual, we have to replace all fluids every 40,000 Km. It is now at almost 80,000.
    Jan 2003
    afaik, honda requires a specific PSF for their PS. better use it na lang just to be on the safe side.
    Quote Originally Posted by non-vtec View Post
    oo naman bro. i already bought an oem psf from the casa recently. i'm just having second thoughts on whether to have the old psf replaced/changed or just to top-up na lang. naka-sched na nga ako kanina pero pinostpone ko na lang muna para bukas
    cvt: oo nga eh. i read some of the posts made earlier that's why i got cold feet. i had the procedure scheduled already for this morning sana but i decided to put it off. i will do it tomorrow morning na lang since i don't think it'll take that long anyway
    btw, i've consulted the manual already and it all it says is to inspect after every service starting at 40000 kms
    Nov 2003
    yup, for hondas and some toyotas it's better to use their own specific psf.
    I'd recommend that you change your power steering fluid since it has never been changed, according to you. Your car is 12 years old already. Water vapor gets into it somehow and the fluid loses its viscosity over time....
    5404:knit:
PS fluid
