Guys need help! ano kaya ang problem pag yung manibela and part ng dashboard nag vivibrate when idle? tapos naka D? especially pag traffic? and mas malakas pag naka ON yung aircon
please advice thank you!
Kung ang vibration sayo e paminsan meron minsan wala. Try mo buksan ung gas tank cap to release presure. Sa akin kasi observe ko from full tank wala vibrate from idle pero pag nag half tank na saka ako nagkakaroon ng vibrate so naisip ko baka nahihirapan humigop ng gas kaya binuksan ko gas tank at nawala naman vibrate. Di ko lang alam kung pressure sa gas tank ang reason pero it works for me.
Posted via Tsikot Mobile App
Marami factors yan, check mo yung idle rpm mo kung nasa normal range.
Check mo rin kung kailan last mo na PMS. Kung recent lang, ipa-scan mo sasakyan mo.
San maganda magpa scan for maintenance? CASA ba? malapit ako Toyota Alabang , ive got 165KMS on my odo
ive notice maluwag din yung idle ko papa adjust ko mamaya may nagpakita sakin na maluwag hehe thanks mga ka tsikot!
Pls. Help. I bought a brand new toyota vios e at 2015. I noticed a vibrating sound from my dashboard. I already referred the issue to the service center. They told me they put some padding in the steering wheel to correct the issue. After i took the car from the service center, the problem still persist, the noise and the vibration from the dashboard is still there. Pls help, have you experience this problem before? Did someone experience this problem before?
no missed engine oil change? whats the mileage on the odometer?
Hello. I just had my 10k pms last week. Its the time I open the problem to them. Mileage is 10k. I am told its the steering wheel thats vibrating in which theyve put a padding but when i drove the car the vibration is still there. I noticed that the problem manifests when the road is not asphalt. I just cant bear the vibrating noise, this is suppose to be brand new, why am i having this problem. Pls help. Pls share ur thoughts on this problem.
A few other things to check:
Engine mount
Fuel quality
Dead or intermittent cylinder (bad sparkplug, ignition coil pack, or fuel injector)
Hello. I had the 10k pms for the car. Its also the time i open the problem to them. They test drive it and heard the vibration issue. Im told its from my steering wheel which they put some padding on it. After the pms and the installation of padding i drove the car back home. After 2 days the problem persist, the dashboard vibration is back. I just cant bear the thought its a brand new car and im having this problem. Pls help. Im no ninja in this field. Pls help.
Hello. I just had the 10k pms for the car. I was told its from my steering wheel after they test drive it. Unknowing of whats happening i gladly agreed in their solution in which they put some padding on it. After the 10k pms and the installation of the padding i drove back home. After 2 days the problem persists. Pls help. Mileage of the car is 10k. Im no expert in this field. Im getting paranoid of this weird sound from the dashboard. Pls help.
Ask for another SA. Create a warranty work order for the said problem. The SA will have to address this. if you dont create the work order. they will not address this issue.
make sure the work order is about the excessive vibration.
in my opinion this could be the steering coupler between the eps and the column.
make your own investigation, po.
exactly where is the vibration? what is causing the vibration? sometimes, when our hand or finger holds onto the cause of the vibration, it stops vibrating.
in my (non-vios) car, my dash vibration was traced to the swivel axis of the glove compartment. na-tanggal yung felt tape. linagyan lang muli, at nawala na vibration.
Hello. I tried holding the dashboard in front of the head unit and the vibration stop. I dont know where specifically the source of vibration comes from but everytime i hold it the vibration stops then it comes again when i release it. Do you have any idea where it comes from? I read some forums and its told the vibration comes from the dashboard and windshield clashing but i dont know if it rules out other possibilities. Pls help.
