Results 1 to 10 of 42
September 8th, 2006 02:33 PM #1
the antenna of my 2000 GLi wont extend anymore. Whenever i turn on the radio, parang nag ga-grind yugn gears ng antenna tapos titigil na lang bigla..pero di pa rin naka extend. Kaya ko ba ito ayusin? Paano po?
Kung kailangan ipaayos sa isang shop, saang shop sa Makati pwede ito ipaayos at magkano po ang usual na binabayaran para sa ganitong trabaho?
Salamat!
September 8th, 2006 03:52 PM #2
learn from my mistakes! huhuhu.
the banawe boys will charge 300-400 to attempt to repair your antenna. if that fails, they will replace it with a surplus one and charge you 2000.
here's the rub -- you can buy a brand-new one from that auto store in megamall (NOT concorde -- ubod ng mahal dun) for only 750.
September 8th, 2006 04:55 PM #3
sir which auto store? tung malapit sa entrance ng parking, floor ng movies? saka how do I have it installed?..kaya ba ako na lang magkabit?
September 8th, 2006 05:30 PM #4
Mura ang antenna sa Autosport (sa Megamall). Kapag car show naka-sale pa sila, Php600.00 for the whole set. Sa SM naman, sa BLADE ay Php1,500.00 ang assembly (presyong Banawe) pero branded kasi (Hirschmann). That's the OEM antenna used on European cars (including MB).
They are universal and pretty easy to install. Nasa packaging na ang wiring diagram. Since you have an existing antenna already with existing wiring, it's virtually plug and play. Removal of existing antenna usually requires loosening the silver thing on the topside.
September 8th, 2006 05:34 PM #5
sir,
ang original antenna ng toyota ay may plastic rod sa loob na may gears. pag naputol plastic na yan, d na gagana ang antenna. motor na lang. and it is not repairable.
pwedeng palitan yan pero masakit sa bulsa estimate ko around 4th for the part pa lang. you are better off buying replacements. 4th mo may antenna ka na, may pang kain ka na sa jolibee 10X. hehe
September 8th, 2006 05:37 PM #6
Mahal talaga ang antenna sa casa. Yung mast lang mismo kapresyo na ng buong set.
Pinalitan na lang namin ng universal yung sa Sentra dati after masagi ng careless pedestrian. Same lang naman ang butas and adjustable ang universal.
Btw, madaming cheap automotive goods sa Autosport. Diyan din ako kumukuha ng wiper blades. Php45.00/pr lang ang refill.
September 8th, 2006 05:45 PM #7
Ganyan din ang problema sa honda vti, maingay ang antenna during radio on-off, kaya ang ginawa ko tinanggal ko ang antenna ang dismantell it, sira ang plastic gear kaya maingay, binalik ko na lang at disconnect ang electrical connector for the motor, pero balik mo parin ang isang wire para sa antenna yun, wala nang ingay pero hindi na gumagalaw antenna ko ngayon. manual na lang kung hihilahin ko or push ko pabalik sa loob.
September 9th, 2006 11:31 AM #9
September 9th, 2006 12:17 PM #10
