Results 1 to 4 of 4
    Aug 2012
    Good day to all. Hingi lang po sana ako ng advice kung ano ang mga dapat kong unahin sa mga sumusunod na for replacement and/or repair:
    1. Ball Joint
    2. Rack End
    3. Tie Rod End
    4. Suspension Arm Bushing Big and Small
    5 Engine Support Front and Rear
    6. Steering Boot
    7. Speedometer Repair (not functioning)
    8. Shocks Replacement
    9. Radiator Cleaning (Kulay baha na yung tubig)
    10. Clutch Disc, Pressure Plate, Release Bearing
    Limited lang din po kasi ang budget at hinde kaya pagsabay sabayin lahat. Ano po dapat kong unahin?
    TIA sa mga magrereply.
    you need to prioritize the things that can make your car run optimally:
    1. radiator
    2. clutch
    3. engine support
    4. rack joint, rack end, tie rod, bushings, steering boot
    5. shocks
    7. speedo.
    imho.
    Aug 2012
    Quote Originally Posted by 1D4LV View Post
    1. radiator
    2. clutch
    3. engine support
    5. shocks
    7. speedo.
    imho.
    Thank you sir 1D4LV. Regarding the radiator, can you sir recommend a shop that is trusted on doing the cleaning? I'm from San Juan.
    Or can it be DIY?
    Quote Originally Posted by bexxprojects View Post
    Or can it be DIY?
    not familiar with the location bro.
    pwede naman DIY, kaya lang kailangan mo ng high pressure hose pambuga sa loob.... pero ipa linis mo na lang, since yung mga cleaning shops sometimes use chemicals to remove the clogs inside.
Need advice on what to prioritize... Parts for replacement / repair
