Results 1 to 10 of 11
- Aug 2003
- 46
May 28th, 2004 02:54 PM #1Sirs,
Ask ko lang if it is essential to install gauges katulad nung nakikita ko sa ibang kotse preferably pangHonda Civic SIR yung nasa may left upper ng dashboard. Amp,volt,boost,oil and water yata yon? Ano ang common na kinakabit?
- Aug 2003
- 46
May 28th, 2004 04:24 PM #3Nagpalit ako ng cam adjustable na and may turbozet ako which one will you prefer na pwede ko ikabit na gauge?
May 29th, 2004 10:18 AM #4
get the A-pillar gauges. alam ko oil pressure, voltage, and boost (?) ata kasama sa set na yun eh. not sure though.
- Aug 2003
- 46
May 31st, 2004 11:25 AM #6
air fuel ratio, fuel pressure, pati oil pressure pala yung kadalasan na nakadisplay sa A-pillar gauges pare.
May 31st, 2004 12:58 PM #7
ako din may tanong sa gauge although simple lang. what do i need to have fixed if the gas gauge is off? kasi kahit ipa-full tank ko it only gets up to 3/4 on the gauge. tsaka wala na 'yung empty fuel light, 'yung separate light na nagsasabi na magpa-gass ka na. kasi naubusan na ako ng gas once kasi hindi na pala umiilaw. badtrip.
- Aug 2003
- 46
May 31st, 2004 04:27 PM #9Ano mas magandang brand when it comes to illumination Autogauge or Splitfire na gauge at shiftlight? At meron bang nabibili na Shiftlight lang?
May 31st, 2004 04:43 PM #10
yup may nabibiling shift light lang. alam ko autogauge is cheaper than splitfire. correct me if i'm wrong nalang.
Xiaomi E-Car
