Results 1 to 11 of 11
    Aug 2003
    Sirs,
    Ask ko lang if it is essential to install gauges katulad nung nakikita ko sa ibang kotse preferably pangHonda Civic SIR yung nasa may left upper ng dashboard. Amp,volt,boost,oil and water yata yon? Ano ang common na kinakabit?
    kung stock lang naman ang kotse mo, porma lang yun at gastos lang IMO.
    Aug 2003
    Nagpalit ako ng cam adjustable na and may turbozet ako which one will you prefer na pwede ko ikabit na gauge?
    get the A-pillar gauges. alam ko oil pressure, voltage, and boost (?) ata kasama sa set na yun eh. not sure though.
    Aug 2003
    Sir tnx sa info.
    air fuel ratio, fuel pressure, pati oil pressure pala yung kadalasan na nakadisplay sa A-pillar gauges pare.
    May 2004
    ako din may tanong sa gauge although simple lang. what do i need to have fixed if the gas gauge is off? kasi kahit ipa-full tank ko it only gets up to 3/4 on the gauge. tsaka wala na 'yung empty fuel light, 'yung separate light na nagsasabi na magpa-gass ka na. kasi naubusan na ako ng gas once kasi hindi na pala umiilaw. badtrip.
    cable mo putol na siguro pare. try mo maghanap sa surplus.
    Aug 2003
    Ano mas magandang brand when it comes to illumination Autogauge or Splitfire na gauge at shiftlight? At meron bang nabibili na Shiftlight lang?
    yup may nabibiling shift light lang. alam ko autogauge is cheaper than splitfire. correct me if i'm wrong nalang.
    Aug 2003
    Ss tnx again......
Re:Gauges
