Results 1 to 17 of 17
    Jan 1970
    mga tol..
    help naman diyan... natuluan ng mighty bond yung hood ng sasakyan ko.. any suggestions on how to get rid of that mighty bond.. nag iba kasi kulay ng paint...
    mighty bond? mukhang ala pang solution dyan, specially kung talagang tuyo na. unless kudkurin and i-repaint.
    Wetsanding might help
    meron remover ng super glue sa nga DIY stores.
    Acetone can soften superglue but it might damage the paint's finish.
    Jan 1970
    time for a new paint job i guess. kze car ko i intentionally used mighty bond sa paglagay nung emblems. nagiba rin ung kulay nung nadikitan n even ung nahingahan lang nung mighty bond.
    Feb 2003
    oo wala ng makakatanggal nyan... ako din may marka ng mighty bond sa door... papa repaint ko one of these days.
    I tried visine!!! natunaw agad ewan ko lang kung mag-re-react sa matagal ng nandoon....
    RIDE ON...
    i agree with Blackmagic, baka makuha sa wet sanding...dalhin mo na lang sa Big Bert's Professional Detailers...mas murang solusyon iyon kaysa magpa-repaint ka ng buong hood...
    yup wet sanding, alalay lang
    Jan 1970
    chieffy,
    mukhang mas mahal yata ang solusyon mo kasi.. dadalhin ko pa sa Big Bert's from Cebu he.he.he.
    anyways.. radius niya is 1/4 inch lang so tolerable pa siya.. i'lltry rubbing compound baka pwede pa..
    all,
    thanks for your inputs..
    marwen
    Jan 1970
    Yup...rubbing compound should work. Don't let it stay too long though.
    nyek...oo nga pala...sorry di ko napansin yung location mo...di pa masyadong sanay sa bagong board he he...post ka sa P.A.D...paturo ka na lang kay theveed kung paano mag wet sand...
    subukan mo kaya yung 3M Imperial Wetordry na 2000 ang grit...imho mas control mo paggamit nito kaysa sa rubbing compound...
    tried wet sanding b4, natanggal pero medyo nag fade yung paint, then I used rubbing compound and bumalik naman sa dati.
    THERE IS A SUPER GLUE REMOVER, ALSO MANUFACTURED BY THE SAME COMPANY THAT MAKES MIGHTY BOND SUPER GLUE. IT IS CALLED, WHAT ELSE...
    "MIGHTY BOND REMOVER" !!!!!!!
    LOOK FOR IT, IT ALSO COMES IN A TUBE, AND YES IT IS THE SAME SMALL TUBE THAT MIGHTY BOND IS SOLD.
    AVAILABLE YAN DUN SA HANDYMAN STORE SA GALERIA. SINCE MAY ROBINSONS SA CEBU, I BET MERON DIN DUN.
    sorry for the caps lock, di kasi ninyo alam e hehehehehe! dami nyo suggest e meron na po naimbento para dyan.
    Jul 2003
    Wag kasing nagtetebats sa hood para di matuluan ng "mighty bond" diba.
    yebo, nabanggit na ni ghosthunter...
  17. cj is offline Verified Tsikot Member
    Join Date
    marwen,
    any update ? natanggal mo ba?
Natuluan ng mighty bond
