Results 1 to 10 of 11
- Jul 2005
- 65
August 9th, 2005 04:17 PM #1mga bosing!!
patulong naman... problema ng kotse ko, pag nag take off ako sa umaga, nasasakal pag apak ko sa accelerator. namamatay pa pag hindi ko inangat paa ko.
one click naman yong starter, bagong palit ng fuel filter, spark plugs and contact point. bagong linis yong carburetor. lancer ex boxtype lang po ito.
August 9th, 2005 04:36 PM #2
Have your fuel pump checked. Palagay ko, may diprensya na ito and it's not providing the necessary fuel pressure when you step on the gas pedal.
- Jul 2005
- 65
August 9th, 2005 05:39 PM #4saan po ba location ng fuel pump?
ganito kasi. pag nag take off ako at malamig pa ang makina, namamatay pag sinasagad ko yong accelerator. pag inangat ko, nabubuhay ulit yong makina. pero pag mainit yong makina, kahit isagad ko accelerator eh humahatak naman.
well anyway, ipapa check ko na lang yong fuel pump. yong fuel filter, bagong palit po yon.
- Mar 2005
- 43
August 10th, 2005 08:41 AM #5your fuel pump is located just behind the fan, on top of the aircon compressor, below and infront of your distributor. Have it cleaned or maybe replaced. Mga 1.5k yata replacement part.
- Jul 2005
- 65
August 10th, 2005 08:47 AM #6Thanks for the info. i'll let it be checked this week end.
By the way, i had been using acetone for the last 3 weeks. 2ml per liter of premium shell gasoline. also, pinalitan yong carburetor jets 3 weeks ago from 190 and 120 to 135 and 95 respectively. is it possible that one of this changes caused the problem
- Jul 2003
- 17
August 10th, 2005 09:27 AM #7Originally Posted by cadayjerry
- Jul 2005
- 65
August 10th, 2005 11:17 AM #8Originally Posted by per
- Jul 2005
- 65
August 11th, 2005 09:16 AM #9Bingo!
Per, its the jet nga. i changed the jet last night. binalik ko yong 120 for the secondary jet. pinalitan ko na rin yong main jet from 130 to 150 (hindi nga lang yong stock na 190) and it all works. di na nasasakal kahit malamig makina. lumakas pa ang hatak. thanks pards.
- Aug 2005
- 18
August 11th, 2005 05:14 PM #10try changing vacuum advancer if your motor is equipped. ns may distributor yun. baka sira na.
The Dongfeng Nammi is, for June, the current hot topic among EV groups since it's on promo for...
BYD Seagull
