Results 1 to 9 of 9
    Aug 2004
    tanong ko lang, ano ba dapat gagamitin for isuzu bighorn manual tranny? if motor oil ano dapat spec? and also if gear oil ano dapat spec? nagpapalit din ba ang mga gas stations ng motor oil for the tranny?
    thanks.
    May 2004
    wala ka ba manual? kasi motor oil ng 4jg2 i think is 15w-40 at alam ko yun din sa tranny nya.
    Aug 2004
    niwde11, walang owner's manual yung bighorn (3doors) namin. petron trekker 15w-40 gamit namin na engine oil sa 4jg2. so, pwede ito narin ang gagamitin namin na oil for the tranny? thanks.
    Dec 2002
    Sounds right, motor oil 15w40 for manual tranny of Isuzu. Or sae 30.
    Aug 2004
    thanks guys, i'll just use motor oil 15w40 for the tranny and tcase.
    any idea if 6 liters of motor oil is enough for both tranny and t-case?
    May 2004
    Accdg to manual;
    M/T; Transmission MUA model=2.95 liters; AR-5=2.7 liters; Transfer Case=1.45 liters
    So i think 5 liters is more than enough.
    Jun 2005
    You can never go wrong with 10-30W oil for your engine, but 45W for your manual tranny, I think thats a little bit too thin for that. Most tranny that I work on usually takes between 75W - 90W Gear Oil. And on the transfer case, its the same with tranny except if you have LSD, then you have to be more specific like JL-4 or JL-5.
    Aug 2004
    Quote Originally Posted by niwde11
    Accdg to manual;
    thank you very much for the info.
    Nov 2003
    yeah, for cars like those use slightly thicker gear oil.
Motor Oil or Gear Oil
