Results 1 to 10 of 14
July 18th, 2005 02:22 PM #1
guys i need your advice. yesterday, me and my family went up to my in-laws at tagaytay. somewhere along the way, i felt my vehicle having this vibrations as i was going 100kph. i have driven my vehicle at this speed before even reaching up till 120kph and no vibrations have occured. this is the first time i have felt it in my vehicle. even my wife made the same comment. another thing that we noticed is that when i change my gear to 3rd or 4th gear, parang "kumakadyot" sya. i didn't change my driving habit when changing gears. pero kapag change from 1st to 2nd and 4th to 5th wala naman. i know the fact that nangyayari ito kapag mababa pa yung speed tapos nagchange gear ka na e ganun yung feeling. usually i change to 3rd gear at 25kph and to 4th gear at 45kph or before my rpm reaches 2000rpm. any advice po? btw, thanks for reading, medyo mahaba po i know. i just want all readers to understand what the situation is para mas clear. guys advice po please. nga po pala, i'm driving a mitsu adv ss 02, i just changed my oil recently. thanks in advance.
- Jun 2005
- 113
July 18th, 2005 03:21 PM #3Could be tire imbalance. If the vibration does not seem to affect the steering, it's probably one of the rear wheels.
Have your car's underbody washed and see if it still shows up. Sometimes, dried mud can cause rotational imbalance on the wheels.
Your vehicle is still relatively new, so it's probably not a worn U-joint or an unbalanced propeller shaft.
An extreme angle to the U-joints will also cause vibration, but this usually starts to happen at lower speeds. Just in case, make sure the vehicle did not undergo any major modifications to the ride height, which may cause uncorrected angles in the driveshaft.
July 19th, 2005 07:57 PM #4
so far wala naman me pinagagawa to adjust the height of my vehicle. try ko po yung suggestions nyo. medyo matagal na nga walang underwash vehicle ko.
- 3,754
July 25th, 2005 07:56 PM #6
buong katawan ba ung vibrations o may specific area (ie. likod, harap)? try mo muna patignan ung cheapest suspect ie. wheel allignment/balance. kelan last wheel allignment mo?
- Jul 2005
- 83
July 26th, 2005 10:47 AM #8Originally Posted by jvdejesus05
- Jul 2005
- 83
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
