Results 1 to 8 of 8
- Aug 2007
- 72
May 11th, 2008 09:38 PM #1Hi! newbie here.
medyo mahirap buksan un back doors ng car ko... hindi naman kasi madalas nabubukasan kasi lagi lang ako magisa. ano po ba pde gawin para hindi masyado mabigat/mahirap buksan or isara un door.. walang problem sa pagbukas,,dun sa pagopen wide ng door dun po un medyo mahirap or mabigat ipush or pull.
thanks in advance!
May 12th, 2008 12:46 AM #2
- Aug 2007
- 72
- Aug 2007
- 72
May 22nd, 2008 07:16 AM #4i have put on sewing machine lubricant and wd40 on my backdoors and i noticed an improvement but its not entirely fixed. when the door is half opened, somehow it paused and i can hear sound when i continue opening the door. how do i check the alignment?
TIA
May 23rd, 2008 07:45 AM #5
Adjustment available in the door itself. You can loosen the hinges at the door and moved it as the hinges are bolted into slots that allow for movement. This a two or three persons job, as the door are heavy and will immediately drop to the lowest adjusment sa soon as you loosen the bolts. You will need someone to hold the door in position while you re-tighten the bolts. After that you will need to adjust the striker post on door jamb. It will be mounted to a plate with large phillips screw. You can loosen this screws and tap the striker with hammer up/down or sideways to make door latch well. You will need to do this after you align the hinges. Kaya moto!
- Aug 2007
- 72
May 25th, 2008 02:37 AM #6
May 25th, 2008 02:51 AM #7
- Aug 2007
- 72
May 25th, 2008 03:08 AM #8thanks for the speedy response v6dreamer!!
glad to be a member of this forum.. im learning alot and members are very helpful!
Xiaomi E-Car
