Results 1 to 10 of 13
- Jun 2004
- 103
November 4th, 2007 10:50 AM #1The carb bowl should normally have some gas in it (sa Toyota's kalahati sa viewing window). Pag inapakan mo ang accelerator pedal, the accelerator cable pushes a plunger which pumps the gas out of the bowl and into the jet/venturi in the carburetor's throttle body. This produces a gas spray which is sucked into the cylinders and fuels the engine.
Kapag walang gasoline sa carb bowl, your fuel pump will have to fill it first before the carb can produce a fuel spray - hence hard starting.
You should have the carburetor float adjusted if you are experiencing hard starts.
A new BYD has arrived: Sealion 5 DM-i launches in PH with P1.198-M introductory price | TopGear PH...
BYD Sealion 05 DM-i
