Results 1 to 10 of 14
December 13th, 2007 08:18 AM #1
Mini Crocodile 2ton Jacks are on sale. Anyone of you guys tried this kind of jack? Bukod sa cute , Reliable kaya ito? Thanks!
BANNED BANNED BANNED
- Jul 2003
- 2,267
December 13th, 2007 10:21 AM #2i have one and used it once pa lang during atf change.
ok naman siya. yung nga lang dapat sa hard flat surface mo siya gamitin kasi may gulong siya na uusod habang tumataas yung car. nung ginamit ko yung sa akin eh sa graba nakapark yung car. buti ndi nasira kahit mejo pinuwersa ko hehehe.
nway some things to consider is mabigat siya kesa dun sa stock jack na kotse (yung de-ikot or screw). bulky din lalo na pag sinama mo yung case niya. pero mas ma lift mo yung kotse mo using this as compared to the screw type jack.Last edited by fourtheboys96; December 13th, 2007 at 10:24 AM.
December 13th, 2007 05:02 PM #3
So far, so good sila. But not all croc jacks can lift as high as the other, even if all of them say they can lift 2 tons. Some crocs can't lift my Camry's rear when it's on non-stock rims. Just check the jack as per application, if their lift is sufficient.
As to the weight and bulk, yes, that's true. But as to convenience, that's true also. It makes short work of changing a flat.
December 13th, 2007 05:10 PM #4
meron din ako nito. made in china siya pero okay naman siya.
kabilin-bilinan na lang nung binilhan ko na hindi pwede ito sa van/auv/suv, talagang pang-tsikot lang daw ang jack na ito.
- Aug 2007
- 999
December 13th, 2007 07:06 PM #5So yung mga pang suv eh yung conventional jack lang?
Meron bang crocodile jack na pang suv like crv?
December 13th, 2007 07:44 PM #6
I have a KYK brand 2-ton crocodile jack that I use for my Carnival. I've only used it twice to change or dismount tires, but after using the conventional jack to change my minivan's tire the first time I had a flat, all I can is that crocodile jacks are well worth their weight and bulkiness.
December 13th, 2007 11:58 PM #7
i have it in my car kyk brand, mas ok gamitin to unlike sa screw type na jack..
- 3,790
December 14th, 2007 06:36 AM #8Depende kung ang ride mo ay oto lang ... the 2ton crocs would be enough. Sa pick-up or SUV ... go for the 5ton big crocs.
December 14th, 2007 08:09 AM #10
Thank you po sa mga inputs.
Sa tsikot ko lang naman gagamitin just in case na ma-flattan ako.
Bibili nko mamaya. Salamat po ulit!!!
I didn't know that Tesla is in the PH na pala. I saw one exiting our village (as I was entering). I...
Tesla Model Y
