Gud day sa lahat. Lyk to ask lang ano dapat gagawin pag mag change ng automatic transmission fluid ng Mitsu Adventure. Other than pinapalitan ang fluid may transmission filter rin ba na dapat palitan. thnks! inputs nyo very much appreciated....
for the most part all you need is the fluid. if the atf remains clean then normally there isn't much trapped in the filter. kung napabayaan tho replacing/cleaning the filter is a good idea.
sakin mga 30k sa odo pinapalitan ko na fluid. Fluid lang papalitan. Ibababa yung atf fluid reservoir, drain the old fluid, clean the oil pan, apply gasket maker and re-assemble. Wait for the sealant to dry then fill with new atf.
after nag fluid change 3 bottles of ATF was bought sa shell. may extra ako isa linagay ng mechanic sa likod ng auto. pag dating ko sa bahay tinignan ko Shell DONAX TM yung ATF wala dexron/dexronII specification. I guess i got the wrong fluid in my tranny, pero i havent notice anything yet for about a week. is it ok to continue using this type of fluid in my tranny or it may cause lots of problems. cause if ok lang hindi na ako mag palit ATF.
