Results 1 to 10 of 10
- Aug 2003
- 9,720
October 1st, 2007 08:37 PM #1mods pakilipat na lang if the topic is inappropriate...
i've seen some references on the net on DIY lambda sensor installation, to monitor the a/f mixture for carb engines. wouldn't it be cool if there was a way you could adjust the idle and a/f carb settings from inside the car? meron na bang gumawa nito?
October 2nd, 2007 04:50 AM #2wouldn't it be cool if there was a way you could adjust the idle and a/f carb settings
I saw this P.M.S on the web though: http://need-4-speed.com/efisystems.htm
BANNED BANNED BANNED
- 3,790
October 2nd, 2007 09:00 AM #3can't be done when driving MANUALLY, kasi masyadong maraming parameters and nakokontrol ng A/F - it is not plain air and fuel in reality.
nandyan ang temperature and pressure ng air and fuel which varies a lot during driving.
- Aug 2003
- 9,720
October 2nd, 2007 09:01 AM #4hmmm...actually i had soemthing more mechanical in mind B) as in parang extension lang ng idle and a/f screws.
ung mga ganitong aftermarket EFI kits...kung nasira ba to e tatakbo pa rin ung kotse(albeit with a less then ideal a/f mix)?
October 2nd, 2007 01:24 PM #5
It's such a sensitive thing to adjust, I don't think you want to be twirling away at knobs inside the car while it's running.
One wrong twirl and you're on your way to over-lean conditions and a potential overheat.
- Aug 2003
- 9,720
October 2nd, 2007 08:05 PM #6icic...
ewan ko lang...parang sobrang daming electronics lang kasi in cars these days. parang di ko matanggap that a car would stop running just because the ECU failed or something; sana tatakbo pa rin kahit papano....
...you kids and your newfangled EFI's :D
October 3rd, 2007 05:09 AM #7
though we have strong electric black and decker screwdriver to use it as a a/f screw adjuster. I don't think you can activate the spin accurately. ang laki kasi ng value kahit few degrees lang...
October 3rd, 2007 07:43 AM #8
install a APEXI Turbo Timer. for just 5500 php, it has a function to control the AF ratio..
October 3rd, 2007 08:40 AM #9
October 3rd, 2007 12:12 PM #10
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
