Results 1 to 4 of 4
    May 2012
    mga sir nakakasira ba ng makina ng sasakyan kapag maluwag ang belt at may tagas power steering? honda civic 1996 model ang car ko
    hindi naman nakakasira as in directly affected.
    what can be affected is the way your car performs.....
    May 2012
    Quote Originally Posted by 1D4LV View Post
    buti nalang sir, thanks.. palagi kasing maingay tuwing nagsstart ako ng kotse prang sumisipol yung belt nya, pati pag inapakan ko yung clutch ko sa working level di ba aandar sya ng mbagal parang may mahinang tunog na sumisipol na parang galing sa belt. tinakot kasi ako ng neighbor ko, paayus ko na daw dahil sisirain daw makina ko :D.. tingin ko nga yung performance ang nagbago medyo d na ganun ka smooth driving ko simula nang lumuwag belt at may tagas din power steering pump ko, paaus ko nalang.
    belt slippage yan naririnig mo. the car's poor performance will depend on which belt is loose. one example is if the loose belt is from the alternator, this will cause in poor battery charging. ps fluid leak is not connected with belt slippage. hth!
maluwag ang belt.....
