Results 1 to 10 of 18
- Feb 2005
- 28
February 7th, 2005 06:20 PM #1Guys, help naman po. Yung sasakyan ko grabe init ng front rims nya eh ang tinakbo ko lang naman is from Novaliches to Makati. Ano kaya problema nito. Pina-check ko siya nung week-ends, medyo stack-up yung gulong may ginawa yung mekaniko medyo nawala yung stackup but mainit pa rin siya. Nag-start lang ito nung nagpa-overhaul ako ng brakes ko, pinapalitan ko yung break pad at piston break ba yun. Ano po kaya problema nito? Please help naman po. Thanks.
February 7th, 2005 06:23 PM #2
baka mahigpit ang pagkakabalik ng pads. pero dapat nangangamoy yun. not sure din kung may direct relation sa pag-init ng temperature ng mags/rims.
February 7th, 2005 06:28 PM #3
definitely cos of brake pads, but no idea why, onga baka mahigpit lalo na if new pads.
February 7th, 2005 06:36 PM #5
try doing this....
jack mo yung gulong, tapos paikotin mo... dapat FREE wheeling sya... if not, somethings wrong with your break system.. could be your caliper.
i was told that this could cause some serious trouble... patingnan mo nalang sa mekaniko...
February 7th, 2005 06:40 PM #6
nagpalit bA ng repair kit?baka di maganda pagkagwa nyan..kasi based on my experience,kahit nonstop dirving,di iinit yan..kahit stop-and-go traffic..pa-bacjob mo..kung di bak masabugan ka ng gulong due to exessive heat..
February 7th, 2005 06:59 PM #7
yup..pa backjob mo yan. what more kung biabiyahe ka pa more than the novaliches-makati route.
tires are the only contact point of the car to the ground.
February 7th, 2005 07:40 PM #8
ibalik mo na agad sa gumawa...baka may tama na calipers mo...kailangan na palitan yung kit at di lang pansamantalang remedyo tulad ng ginawa ng mekaniko...
mas mabuti na yung problemang di umandar kaysa di ka huminto dahil nasira na ang preno sa sobrang init na dulot ng faulty brake system...disgrasya aabutin mo...
February 8th, 2005 10:24 AM #9
Baka nga kailangan lang ng caliper rebuild kit.
Hindi naman iyon ganun kamahal.
- Feb 2005
- 28
February 8th, 2005 10:42 AM #10thanks for your advice guys, actually na-try ko na rin i-jack. Ang alam ko nga dapat free wheeling sya but on my observation hirap siya umikot. Napansin ko din na dikit na dikit nga yung pad ko dun sa plate. Guys any shop na mapagkakatiwalaan to do this job yung mekaniko ko kasi may kalayuan sa may amin. Thanks.
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
