I have the same problem but different car. 1 week ko hindi nagamit cage/car ko (Nissan sentra Lec). Nung una mahina redondo. Binaklas ko battery para ipa check - ok nman pero pina charge ko na din for 2 hours. After nun, nag start. I switched off the engine pero ayaw na mag start ulet. Pina-push-start ko umandar. Dinala ko na sa talyer para ipacheck yung starter. It turned out starter ang problem - na pudpod na carbon brush. So palit ako. Wala ako makuha ka sukat so ang ginawa ko eh bumuli ako ng medyo mataba tapos niliha nlang para mag kasya. After mapalitan, ok na ulet. nag start na. Now issue happened again ater 2 weeks. I seldomly use my cage, once or twice a week lang. I checked the brushes again, I was surprised kasi yung carbon brush cap eh madumi na agad. nilinis ko, salpak ulet, ayun nag start na ulet. I was thinking na baka dahil lang sa mumurahin lang na carbon brush binili ko kaya nag ka ganun. Hmmmmmm?
Any inputs will be much appreciated. What can cause this problem? OK nman charge ng battery. Tig 80pesos lang na brushes ang nabili ko. Isang set na yun. Magkano ang range ng magandang klase. -TIA
