Results 1 to 6 of 6
    Apr 2011
    plan ko kasi magpalinis ng MAF and throttle body sa isang talyer dito since hindi naman ako magaling mag DIY. anong sasabihin kong instruction dun sa mag lilinis kasi delicates ang mga parts na ito and ano pa ba pwedeng idamay na palinis bukod sa maf and throttle. TIA
    car is Nissan sentra series 3
    if you don't really need it, don't. cleaning a maf is only a temporary fix, it should be replaced if defective.
    Apr 2011
    ok pa naman daw maf ko kailangan lang talaga linisan. napalinis ko na din sa street specs
    Nov 2006
    sir san po location nyo?
    Try to visit ATA sir Advance Techniques Autoworks sa Pasig..
    Ito sir FB page nila..
    http://www.facebook.com/rodmixalot#!...98327386876148
    Experts in Nissan sir mga Mechanic nila.. Just look for Jonathan
    Jan 2010
    Quote Originally Posted by sn0wbLind View Post
    cleaning the MAF of nissan is risky even if you use carburetor cleaner. there is a product that is specifically used for MAF. however, nissan MAFs clean themselves by delaying the turning off of the MAF after engine shutdown. this enables the hot wire element to "burn off" whatever dust or contaminants that cling to the sensing element. spraying it with other than MAF cleaner spray is like doing russian roullette, sometimes you get lucky or sometimes you get luckier
    Apr 2011
    napalinis ko na yun throttle and MAF. so far so good naman what do you mean by "like doing russian roullette, sometimes you get lucky or sometimes you get luckier"
MAF and Throttle Body cleaning
