Results 1 to 10 of 10
- Sep 2017
- 25
January 26th, 2018 11:28 AM #1
good day mga sir, paki check po yung image, ganyan po kadami yung tubig na lumalabas kapag unang start sa umaga. dati patak patak lang po, ngayon po andami na. tapos pansin ko medyo humina hatak. sobrang bagal nya kapag simula ng takbo, tapos kapag umabot na sa 20kp/h biglang bulusok andar. patulong naman po mga sir. salamat po! Mitsubishi Dingo matic po ang kotse.
- 54,286
January 26th, 2018 11:57 AM #2
- Sep 2017
- 25
January 26th, 2018 12:07 PM #4
January 26th, 2018 04:04 PM #5
January 26th, 2018 04:11 PM #6
how old is the vehicle?
January 26th, 2018 07:44 PM #7
While it is true that the presence of condensate is normal, excessive water coming out from the exhaust pipe could mean that the cylinder head or engine block is leaking. The jacket water will be ejected through the exhaust manifold as you run it and collected somewhere once you stop the engine and then when you start it first time in the morning, you'll see the condensate. You can verify this if the coolant level in your radiator is decreasing. Otherwise, everything should be normal except for your last concern about sudden acceleration.
- Sep 2017
- 25
January 27th, 2018 01:27 AM #8uhm 5 years from the first owner, then almost 7 months now as a second owner sir. this is from subic, japan car.
as of now sir i haven't checked or noticed much about the coolant level, so i will start to check this starting tomorrow morning. thank you everyone for your help.
- Jan 2018
- 1
- Dec 2007
- 727
January 29th, 2018 03:26 PM #10
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
