Results 1 to 10 of 18
- Jan 2010
- 55
December 14th, 2010 06:19 PM #1I have a Honda Civic 96 LXI at napansin ko mababa ang idle nya pag naka neutral. Nasa 500 rpm. Tapos pag naka on ang aircon hindi sya tumataas. Pina adjust ko na ang rpm to 1000 pero pag nagstart lang ng engine sya ganito.
Recently biglang namatay ang aircon at stereo while driving. Tapos napansin ko nag dim ang light. Hindi naman namatay ang engine. And bumagsak talaga ang rpm to 200. Tumaas ng unti to 300.
After this e nung nagpark ako hindi ko na mastart ang engine due to discharge battery. Ano kaya ang problem?
December 14th, 2010 06:37 PM #2
parang minulto ang kotse mo bro... jk.
wait ka lang at me mag-advice sa iyo maya maya lang...
December 14th, 2010 07:29 PM #3
start with the obvious. check the battery state of charge and condition, check the terminals to make sure they are clean, free of corrosion and tight. check the grounding to the engine block (usually, hondas put them on the top of the valve cover and usually loosen up). check the ground wires to the engine block. to quantify the condition of the connections, perform a voltage drop test at each connector or connection. the maximum allowable drop should not exceed 0.1 volt per end of the wire at the connector.
- Jan 2010
- 55
December 14th, 2010 10:37 PM #4Bago ang battery terminals ko. I had it replaced because of original terminals from honda is metal not copper. Bago din ang battery ko. I bought a new one from Motolite last August 2010.
I don't know how to check the grounding to engine block. I will have it check later. I read from other posts here the idle rpm is due to IACV and sensors that are not clean.
- Nov 2005
- 255
December 14th, 2010 10:52 PM #5
- Jan 2010
- 55
December 14th, 2010 10:56 PM #6Can a low idle discharge a battery? That's given the fact that your headlights, aircon and stereo are on.
THE AUTO SPECIALIST
- Mar 2006
- 607
December 14th, 2010 11:02 PM #7get it scanned and from the live data lists ,check the iac counts. some scanners can manipulate engine rpm .
a trained tech will be able to do these tests for you .
i have worked on some honda cars and found out that the IACV always go .
- Jan 2010
- 55
December 14th, 2010 11:44 PM #8
- Nov 2009
- 456
December 15th, 2010 05:14 PM #9
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 17th, 2010 08:08 AM #10start with the simple, have the throttle and iacv cleaned. if it doesn't work then you'll probably need to buy a new iacv.
