Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Aug 2003
    my car (1993 mazda 626) has suddenly developed a ton of cooling problems. i've already had the big hoses replaced (to the tune of 2000 petot thanks to rapide... grrrr...) and the aux fan as well since it died.
    however, it is STILL losing coolant (about 1/3rd liter every day). i know there is a problem in my valve cover gasket because the #2 spark plug has some oil on it. could a gasket leak cause water to get into the engine? honestly i haven't seen anong kulay nung exhaust gas (dapat puti kung may tubig, right?) kasi ang dilim dilim ng tint.
    there is no water in the crankcase oil though...
    radiator leak? or water pump?
    Dec 2003
    failing radiator cap could be one of the culprit
    yup. check your radiator cap, baka may leak na dun.
    Signature
    Baka my crack 'yong coolant resorvoir.
    coolant coming out from water pump breather or kapag wala kang nakita externally na leak malamang cylinder head gasket.
    Quote Originally Posted by DeltaBravo
    ako din ganun problem and may tagas na din head gasket ko.
    eto ba culprit kaya madalas mawalan ako nang 2big.
    Feb 2005
    Check mo rin drain plug baka maluwag lang.
    Apr 2005
    medyo mahirap hanapin kung patak-patak lang, look for tell-tale signs on the garage floor kung saan nakatapat yung tulo. Or check the engine thoroughly kung may makita kang dried-up coolant material - usually around that area may leak.
    Aug 2003
    already changed the cap...
    rapide's inspection couldn't find any leaks. actually they just changed the hoses because they were really old and fluffy... but still not leaking.
    Mar 2005
    Check mo kung saan may tumutulo. Either from radiator, hoses, or water pump. But don't lose your cool bro.
    Dec 2003
    kng di talaga makita use a UV dye leak detector, ung gnagamit sa A/C leak detect, but it uses a different dye. then use a uv light to find the leak. ewan lng kng meron dto.
    Apr 2005
    pa check mo sa mechanic yun daluyan ng tubig sa engine mo baka me leak o sira yun gasket ,
    Quote Originally Posted by axelangel007
    Minsan hindi mo makita na merong tulo kasi pinhole at mabilis magevaporate kasi hot. Try mo after a trip buksan mo engine compt and monitor mo kong merong mga wet areas. Ganyan kasi naging experience ko. nagbabawas ng tubig pero wala kong makitang tagas. Meron palang pinhole kaya pagkatapos gamitin mainit ang makina kailan lang lumalabas kasi masyadong maliit. Mabilis naman mawala ang trace ng tubig kasi mainit.
    why not open your window so you can see the color of the exhaust? a leaking head gasket not only causes a loss of coolant, it leads to rapid overheating. nago-overheat pa ba or loss of coolant lang?
    since the hoses were recently replaced, then they drained the radiator di ba? so baka maluwag lang ang drain plug. remember that the drain plug turns counter-clockwise to close, left hand thread kasi (as opposed to the faucet in your kitchen and bathroom that turns clockwise to close). OR, maybe by turning the valve counterclockwise TOO MUCH the plug seat became loose and is now leaking (since it turns clockwise to tighten, right hand thread). gulo ba? hehehe! yun plug has 2 parts, seat and valve. the seat turns clockwise to install on the radiator, the valve turns counterclockwise to close.
    check also the water pump baka naman may leak na. if there is additive in the water then you might see a red/pink/green residue near the water pump shaft or pulley if this is the problem.
    Jan 2003
    pa check mo sa ibang shop.
    wag mo na balik sa rapide...
    Aug 2003
    it has (almost) overheated several times, kaya ko napansin merong problem. :P
    di pa naman tumirik, pero ilang beses na...
    pero ngayon dagdag ng dagdag ako ng tubig every day (mga 1/3 liter) di na siya nag-o-overheat. pero 2 weeks ago ilang muntik dahil sa busted aux fan.
    May 2005
    Ganyan din ang problem ng 97 vanette ko. Sakin walang leak or whatsoever. Umaawas lang ang tubig sa reservoir pag matagal umaandar ang makina at nakahinto / pag kapatay ng makina matapos ang byahe. Pinatignan ko sa mga mekaniko di rin nasolusyonan. Ayun up to now di pa nasosolve. Dami tuloy nasasayang na coolant, tumataas pa ang temp.
    Aug 2003
    water pump daw sabi ng some guys in evangelista. funny that i specifically asked about the water pump kung bumibigay na sa rapide and sabi nila walang tama daw... weird.
    i KNEW i should've had that #$^%#$!! water pump replaced nung nagpalit ako ng timing belt. mahal mahal ng labor. anyway punta ako sa suking tindahan sa banawe for a second opinion.
    pre... wala bang mga leak sa sahig ng garahe mo? usually jan mo rin malalaman kung saan galing ang leak.
    mahirap nga mag tanggal ng water pump ng mazda. buti na lang kilala namin ung mekaniko kaya hindi kami tinaga sa presyo.
losing coolant, help!  :P
